Thread: Issues binding dynamic blocks
    The Silent Type
    2020-10
    Default Issues binding dynamic blocks
    Hi everyone!
    Here at the office we use Autocad 2016, the complete version
    Let me explain what happens, and see if someone can help me with this.
    I use dynamic blocks in my "base" CAD drawings that will be xref to a final sheet or several sheets (it is just a simple polyline with associated hatch and stretch action in both directions);
    When I manually bind (xref tool palette -> right-click on reference name -> bind -> insert) a sheet, the dynamic block remains as it is; but when I e-transmit (etransmit -> bind-insert) a set of sheets (doing this as a faster method), the dynamic block acts weird, the polyline remains but the hatch returns to the original dimensions when the block was drawn.
    In this attached image you can see the mess up; the walls highlighted in yellow is one xref, these walls behave well in the binding; the walls highlighted in blue is another xref, and these walls, well you see the problem.
    It is the same block in both references.
    I'm losing it as to why this happens with one method and not the other
    Thanks in advance for your comments!
    Turlock, CA
    6,420
    Default Re: Issues binding dynamic blocks
    Quote Originally Posted by JoBlake View Post
    It's pointless to figure out why they are different, they just are. Obviously they use different programming logic. To do dwgs in a batch, I would write a script file and process it with ScriptPro.
    C:> ED WORKING....
    LinkedIn
  1. Sharing Dynamic Blocks - Palette & Catalogue Issues
    By Warr_E_Er in forum Dynamic Blocks - Technical
    Last Post: 2014-08-13, 09:15 PM
  2. Dynamic Blocks - Creating dynamic bolt blocks
    By jake1889 in forum Dynamic Blocks - Technical
    Last Post: 2014-08-08, 12:56 PM
  3. issues! dynamic blocks with attributes.
    By emodderman in forum AutoCAD General
    Last Post: 2008-02-14, 04:51 PM
  4. Anyone had any issues using mviewblocks in Dynamic blocks?
    By CADMama in forum Dynamic Blocks - Technical
    Last Post: 2006-01-23, 07:39 PM
  5. Copied dynamic blocks not dynamic anymore..
    By kwong in forum Dynamic Blocks - Technical
    Last Post: 2005-07-08, 10:49 PM
Tags for this Thread
