Thread: Roof Join
    Default Roof Join
    Hello again, some what of a rookie, attached is a roof that obviously is incorrect, in order to correct it, would I need to several roofs or can is one roof doable?. Thank you very much.
    Dallas
    2015-08
    199
    Default Re: Roof Join
    This is not possible to do as one roof. I would do it as 5 individual roofs as shown in the attached image and then use the join tool to connect them.
    Attachment 108471
    Thank you very much Marm, it worked!...sweet
    2010-10
    Chicago, IL
    376
    One roof works just fine. Use 'Join Roof' tool to connect/extend roof to wall under the eaves.
    Awesome! thanks pij
  1. Replace WALL JOIN tool with DISALLOW JOIN tool
    Last Post: 2017-11-02, 12:36 PM
  2. 2013: Join/Unjoin Roof - Can't keep wall and roof joined
    By StacyJennifer in forum Revit Architecture - General
    Last Post: 2012-10-12, 12:48 PM
  3. join gable roof with polygon 5 sides roof
    By o_dragos in forum Revit Architecture - General
    Last Post: 2010-11-14, 04:17 PM
  4. Join roof - cant join over 2 seperate ones
    By still.james in forum Revit Architecture - General
    Last Post: 2008-05-15, 04:42 PM
  5. walls with sweeps won't correctly join an extruded roof
    By janunson in forum Revit - Known Issues & Work-Arounds (Read only)
    Last Post: 2003-07-02, 04:14 PM
