Hello All,
I have a client that wants CAD drawings of the pdf bid package that I put together for them. I created the bid package in AutoCAD Plant 3D with ortho views. One sheet had xrefs attached. I performed the eTransmit command and then made sure the one dwg that had xrefs was mapped correctly to the specific xrefs and emailed the zipped folder of CAD dwgs to them. Now, they are having trouble opening the files. They get an error message stating that "File not found - C:\USERS\DMEREDITH\DOCUMENTS\TEST.SHX". I understand that this is a shape file or font text, but they should still be able to open the dwgs with no ill affects. Questions:
1. How do I find and delete the .shx file?
2. They are running Dessault Systems, could that be a reason why they are having trouble since I created all of the dwgs using Autodesk AutoCAD? If so, do I need to create a STEP file of all of the dwgs?
