Thread: PDF file size problem
    Cairo - no, not Illinois
    5,069
    Default PDF file size problem
    I've got a giant PDF, created from scanning a stack of hard copies on an HP 2600 eMFP scanner/plotter. File size is about 1.4 Gb - Acrobat, Photoshop, Bluebeam, and AutoCAD all **** out on it. Any suggestions on a) something that can open it, and b) something that can separate it into manageable chunks?
    Super Moderator CAtDiva's Avatar
    2015-10
    Where pedals spin to move wheels
    442
    Default Re: PDF file size problem
    Ouch! You've already tried the ones I can think of. I'd probably circle back to re-scanning the set: change the scan to lower resolution (unless you really need it as high as it was) and/or breaking the set into multiple sets.
    5,069
    yeahm I wish i could scan at a lower resolution -- but the hardcopies have left the building, with the sub's stamps on them. Part of a Friday PM scramble to hit a deadline, with no time for checking. And the job was on hiatus since the 2018 hurricane hit the jobsite
    Chrome will open the PDF, recognize the correct number of pages, but only show/print the first one.
    Turlock, CA
    6,420
    I would contact Bluebeam support and see if they have any suggestions/tricks.
    You might also try this online editor. you can upload from Dropbox, OneDrive and it has a 30 day trial.
    C:> ED WORKING....
    LinkedIn
    5,069
    thought about trying one of the on-line editors, but these sheets have scanned seals and signatures -- I am not comfortable with letting those out in the wild
  1. Adobe PDF vs Acad PDF file size info.
    By madcadder in forum AutoCAD Plotting
    Last Post: 2006-11-30, 06:06 PM
  2. DWF vs DWG vs PDF File Size comparisons
    By sbrown in forum Revit Architecture - General
    Last Post: 2005-12-19, 09:26 AM
  3. Image size too large and PDF wipeout problem
    By phaveman in forum AutoCAD General
    Last Post: 2005-09-14, 10:18 PM
  4. PDF File size too large
    By jfields.61630 in forum AutoCAD Plotting
    Last Post: 2005-06-04, 01:08 AM
  5. Creating PLT & PDF file size 2005
    By sandy.sebastian in forum AutoCAD General
    Last Post: 2004-08-26, 07:58 PM
