Thread: Alignments effect on TIN
    Raleigh, NC
    944
    Default Alignments effect on TIN
    I am seeing that when modifying a proposed surface with feature lines that cross alignments is causing some of the triangles to not adhere to the new feature line.
    Is there a solution?
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,105
    Default Re: Alignments effect on TIN
    Are the two entities in the same site? Feature lines within the same site are affected by other feature lines in the site. Suggest moving one or the other to a new site.
  1. TIN Surface saved as *.tin file
    By skorche in forum AutoCAD Civil 3D - Surfaces
    Last Post: 2010-05-31, 01:32 PM
  2. Microstation DTM to AutoCAD TIN
    By andy in forum AutoCAD Civil 3D - General
    Last Post: 2006-12-19, 02:10 PM
  3. Generate Tin or Grid surfaces with Map 3D 2007
    By shaon9902 in forum AutoCAD Map 3D - General
    Last Post: 2006-08-22, 04:58 PM
  4. Deleting a point in a tin surface
    By dmarx in forum AutoCAD Civil 3D - Surfaces
    Last Post: 2006-05-19, 01:07 PM
  5. Calculate a Volume at an elevation for a TIN
    By cjtrull in forum VBA/COM Interop
    Last Post: 2006-02-25, 07:24 PM
