Thread: Super Purge
    Wish List Administration
    2011-08
    4,581
    Default Re: Super Purge
    Summary: An Autodesk approved Super Purge routine
    Description: An Autodesk approved super purge routine (or set of such) that has a multiple checkbox allowing default settings to be retained or changed (similar to the Overkill dialog box). Some options would be to eliminate regapps, perform overkill (even within nested blocks), perform an audit, remove any multiple handles (causing the "*Warning* Multiply owned object, handle "XXXX" " message), stripping all Mtext widths, sets all properties to ByLayer (including nested objects) and flattens all objects to 0 height (even thickness).
    This would be an ideal routine for most outside drawings received.
    Product and Feature: AutoCAD -
    Submitted By: e3do2112 on 11/11/2020
    2011-08
    4,581
    Exclamation Re: Super Purge
    Super Purge
    Product and Feature: AutoCAD - Lisp
    2011-08
    4,581
    Super Purge
    Certifiable AUGI Addict
    2001-03
    Tallahassee, FL
    3,479
    Most of that could be done with a macro starting with -Purge adding Audit in there with a Yes behind it as well.
    Quick macro to Purge regapps:
    ^C^C-Purge;RegApps;*;N
    Tom Beauford P.S.M. - Civil 2020 on Windows 10 Enterprise
    Design Analysis - Leon County Public Works/Engineering Wrap [CODE] tags around selected text
    Ph# (850)606-1516 Home Page
