Thread: Trying to backup workspaces (not the full CUIX file) using LISP
    2018-10
    10
    Question Trying to backup workspaces (not the full CUIX file) using LISP
    Hello y'all!
    Simple question, not so simple answer I'm guessing. I have a LISP that will backup all users ACAD Profiles, PGP file, and CUIX file to the network based on the day and time as well as when the last backup happened. I'd like to find a way to pull out JUST the workspaces for backup. Any solutions would be incredible, leads and starting points work as well!
    Thank you.
    Earth
    9,802
    Default Re: Trying to backup workspaces (not the full CUIX file) using LISP
    A .CUIX file is nothing more than a .ZIP file. Inside that file is a file named "WorkspaceRoot.cui" - I suspect that contains the workspace data.
    See if that helps.
    R.K. McSwain | CAD Panacea |
    Certifiable AUGI Addict
    2001-03
    Tallahassee, FL
    3,477
    More options:
    How to transfer workspaces between different versions of AutoCAD: https://knowledge.autodesk.com/suppo...f-AutoCAD.html
    Transferring workspace to another computer for AutoCAD Products: https://knowledge.autodesk.com/suppo...-computer.html
    Tom Beauford P.S.M. - Civil 2020 on Windows 10 Enterprise
    Design Analysis - Leon County Public Works/Engineering Wrap [CODE] tags around selected text
    Ph# (850)606-1516 Home Page
    2003-07
    473
    The cuix to look for is the "main customization file" like for me C3D, its in a long path under c:\users\xxxxx\appdata...............\c3d.cuix copy and rename to zip as suggested. If you dont know use Option and look at customization files.
    Earth
    9,802
    Quote Originally Posted by BIG-AL View Post
    You can also just drop this in Windows Explorer, after you confirm product and version.
    -----> %appdata%\Autodesk\<product>\<version>\enu\Support
    (portions in blue will vary depending on the product and the version)
  1. Edit Cuix files with batch or lisp
    By Trevor Deleske in forum AutoLISP
    Last Post: 2017-12-11, 12:50 PM
  2. Enterprise cuix to be active in all workspaces?
    By zride91 in forum AutoCAD CUI Menus
    Last Post: 2013-02-27, 09:12 PM
  3. Backup files should go into a "Backup" folder
    Last Post: 2012-03-09, 06:06 PM
  4. Missing pdfic.cuix pdfmacad.cuix
    By kathleen.143968 in forum AutoCAD CUI Menus
    Last Post: 2010-02-01, 10:51 PM
  5. is it possible to convert a cuix file to a cui?
    By unjust in forum AutoCAD General
    Last Post: 2009-05-12, 01:47 PM
