Results 1 to 10 of 12
Thread: how to convert non-planar 3d polyline to surface
    2020-11
    2
    Default how to convert non-planar 3d polyline to surface
    Need to convert a non-planar 3d polyline to surface. Have found a few suggestions such as CONVTOSURFACE & EDGESURF but they're not working for me or I'm doing it wrong. File attached
    Active Member dotson's Avatar
    2005-01
    54
    Default Re: how to convert non-planar 3d polyline to surface
    Your drawing is assigned a coordinate system of ...
    Command: CGEOCS = "HARN/10.UTM-10F"
    ... which is in US Survey Foot. However your units are Architectural Inches? Also, the coordinates of your objects are outside the usable rectangle of the coordinate system assigned. Those problems aside, attached is an AutoCAD Surface of your 3dPolyline
    2020-11
    2
    Thanks. Yeah it's a client file & didn't wanna do too much to it.
    So you're gonna give a man a fish?
    Thanks again,
    Mike
    2022-02
    5
    I have struggled many hours trying to convert this object to a surface.
    My biggest hurdle now, is that I am unable to get the PLines to join.
    I have re-snapped, changed Fuzz settings, changed precision settings, moved, and added vertices, tried with all set to open, and closed.
    The red PLines are put in at crucial points to pull the sides to the dimensions needed. I will be placing a few more on the top.
    I need to convert this into a surface that I can sculpt, then convert to solid. I will then set the shell thickness, then add external mounts. This will be a 3D printed fuel tank.
    What am I possibly missing to join, and convert to surface?? With a planar shape of any kind, surface convert works flawless.
    Any help would be greatly appreciated.
    Regards
    Rod
    Turlock, CA
    6,301
    I'm not sure what operation you are trying to perform. The 3D polylines on the sides are closed. The red lines are lines, not plines.
    C:> ED WORKING....
    Turlock, CA
    6,301
    I created a surface of the width sides. I think you need more information to create the complex sides.
    C:> ED WORKING....
    2022-02
    5
    I have been able to do what do did, but i am trying to close the sides, or make them surfaces that i can extrude.
    Thank you for looking at this
    2022-02
    5
    Cannot get this closed PLine to convert to surface, or imprint .
    What am i doing wrong ?
    Turlock, CA
    6,301
    Quote Originally Posted by usa1st799342 View Post
    As I mentioned before, to do it in AutoCAD, you would need more information, e.g. lines across the surface, to give it an idea of how to create the surface. I wasn't able to find a command in AutoCAD or Inventor to convert a 3DPOLY to a surface, but I found the PATCH command in Fusion360.
    C:> ED WORKING....
    2022-02
    5
    Thank you so very much. any Idea of how to convert 3D closed PLine or Spline to 2D so I use the Offset tool. I do not have the Civil Eng Cad version. Have a great week
    rod
  1. Pattern of a Feature on a Non Planar Surface
    Last Post: 2012-12-15, 06:03 PM
  2. Extrude a conical face - Non-planar faces cannot be extruded and are ignored...
    By hanish_kapoor in forum AutoCAD 3D (2007 and above)
    Last Post: 2010-05-31, 09:04 AM
  3. Convert a Polyline to a 3D polyline?
    By Mr Cory in forum AutoLISP
    Last Post: 2007-07-11, 08:22 PM
  4. Convert 3D Polyline to 2D Polyline
    By kyleschmeusser in forum AutoCAD General
    Last Post: 2006-02-14, 07:08 PM
  5. Replies: 9
    Last Post: 2005-06-29, 09:49 PM
