Thread: pressure pipe catalog missing
    2004-06
    Slidell, Louisiana
    972
    Default pressure pipe catalog missing
    trying to set the pressure pipe catalog and it says "there are no pressure network catalogs in this folder."
    here is where I navigated to :C:\ProgramData\Autodesk\C3D 2021\enu\Pressure Pipes Catalog\Imperial
    under Imperial there are two folders DWG and IMG.
    not sure what i'm doing wrong.
    Cairo - no, not Illinois
    5,069
    Default Re: pressure pipe catalog missing
    stop going down the tree at "C:\ProgramData\Autodesk\C3D 2021\enu\Pressure Pipes Catalog"
    2004-06
    Slidell, Louisiana
    972
    I tried that, still says no pressure network catalogs.
    5,069
    Under "Pressure Pipes Catalog" om my machine are folders for "Imperial" and "Metric"
    Under Imperial are a half-dozen folders, and a half dozen .sqlite files with the same name. The DWG and IMG folders are one step lower. Looks like the 'catalog folder' needs to be "Imperial" in order to find the .sqlite database files.
  1. 2016: Pressure Pipe Catalog not Loading
    By mikeosborne in forum AutoCAD Civil 3D - Pipes
    Last Post: 2018-11-15, 11:56 AM
  2. 2017: Using Pressure Pipe Catalog in different workstations
    By denisgonzalezg189 in forum AutoCAD Civil 3D - Pipes
    Last Post: 2017-07-05, 10:23 PM
  3. 2016: Pressure Pipe Types and Catalog
    By jmckee706462 in forum AutoCAD Civil 3D - Pipes
    Last Post: 2016-06-30, 05:06 PM
  4. Negativ Pressure Drop and Static Pressure
    By amigost in forum Revit MEP - General
    Last Post: 2014-02-27, 05:14 AM
  5. 2011: Pressure Drop/Static Pressure
    By RevitSOS in forum Revit MEP - General
    Last Post: 2013-04-05, 08:08 PM
