Thread: Failed Upgrading 2019 to 2020: Corrupt Model Error
    2016-10
    Default Failed Upgrading 2019 to 2020: Corrupt Model Error
    Was attempting to upgrade a series of R19 models to R21 and I keep on the error that the files is corrupt and needs to be repaired manually. I believe several models were created off the a model in the group so the same issue has most likely translated to others.
    I have tried detaching, purging, deleting cache files, renaming files, the whole shebang. I have tried looking at the journal but I haven't been able to decipher the issue and find the error.
    If anybody is looking for a challenge could you please take a look or offer and suggestions.
    All AUGI, all the time Duncan Lithgow's Avatar
    2006-09
    Denmark
    621
    Default Re: Failed Upgrading 2019 to 2020: Corrupt Model Error
    Maybe you could make a more comprehensive list of what you tried. I'm not going to make a long list of suggestions for things you might want to try ... you might have already tried them. You've failed to mention addons, links, audit ...
    2002-09
    Madison, WI
    5,687
    First open the R19 model with the Audit check box checked. When you save check the compact checkbox.
    The other way I've resolved those issues is to save out all of the families. If you have a family that was unable to be saved, that's most likely the issue.
    I'd also suggest that you upgrade version by version.
    2002-09
    Madison, WI
    5,687
    This could be the other issue.
    ' 2 API_ERROR { System.NullReferenceException exception(Object reference not set to an instance of an object.) was thrown from a handler of Autodesk.Revit.Proxy.DB.Events.DocumentOpenedEventArgsProxy event. The API event handler was registered by application Keynote Manager + (457da48a-c5ea-4f6f-8cf3-7c7a1dbd115e). Changes made by this handler are going to be discarded. }
    There seems to be an issue with some of the API builds that you have as well. Based on what the journal says before the model load stream starts, it looks like there's some build errors within a number of your Add-Ins.
    I think there was also an issue with a version of Keynote manager and Collaboration for Revit as well as a CTC tools Suite issue for 2021.
    Just some guesses.
  1. 2019: Doing Revit 2019 Mechanical in Revit 2019 Architectural model
    By mdstenberg783987 in forum Revit Architecture - General
    Last Post: 2020-06-09, 02:37 PM
  2. transferring Autocad 2020 cui to Autocad LT 2020, any problems?
    By danmen101787157 in forum CAD Standards
    Last Post: 2020-02-01, 12:25 PM
  3. 2019: Unable to copy objects Revit 2019/2020
    By c.fanjul in forum Revit Architecture - General
    Last Post: 2019-08-20, 09:05 AM
  4. 2019: Impossible de copier objets en Revit 2019 / 2020
    Last Post: 2019-08-20, 08:57 AM
  5. Convert VB.NET 2013 to 2018,2019,2020
    By jntm226765193 in forum Dot Net API
    Last Post: 2019-04-09, 05:22 PM
