Having a major issue that i can't seem to get corrected. When i create a revision table either for entire drawing or per active sheet i can get the table to generate and display correctly (no issues here), however when i then try and create a revision tag the tag will not display the active row revision number or letter (tried both methods with zero luck).
In the attached JPEG i show that the revision triangle and the edit screen. inside the Revision Tag Value box i can type anything i want (assuming manual override) and hit OK and the box closes and nothing changes. tried hitting the UPdate all sheets button and nothing happens. reopen the edit dialog box for the revision symbol and the Revision Tag Value box is empty again.
Tried to change the IProperties Revision number field on the Custom Tab and also on the Project tab but that did not help any.
