Results 1 to 8 of 8
Thread: Civil 3D 2021 - Alignment Label - parameter - "Perpendicular Direction"
    2020-12
    4
    Question Civil 3D 2021 - Alignment Label - parameter - "Perpendicular Direction"
    There is a parameter for the "Station Offset" label called "perpendicular direction". This gives the direction from the Alignment to the Station Offset location.
    NEED: I need to get this function into the Structure Labels, but it is not there in the drop down list. I have developed expressions for labeling Station and Offset in our Profile View but without knowing the angle to the perpendicular connection to the alignment, my expression only works with an alignment with 0 rotation. I have tested by manually getting the number from the Station Offset style and plugging it in and it works perfectly. I need to get this parameter into the options when editing Structure Labels. I can provide more information or examples if someone can help with this. Thanks!!
    Cairo - no, not Illinois
    4,881
    Default Re: Civil 3D 2021 - Alignment Label - parameter - "Perpendicular Direction"
    Perhaps I'm misunderstanding, but Station and Offset are available in the structure label editor, so there's no need to do an expression or try to calculate anything...
    2020-12
    4
    Hi cadtag, we are showing a standard GRATE in the plan view of the Structure. The issue occurs when rotating the structure to line the grate up to the FLOW LINE in the design. The expression I'm talking about takes the Station and Offset of the Structure, then calculates the Station and Offset to the GRATE. In order to do this, the "perpendicular direction" needs to be known to compensate for the angle of the offset to the alignment at that station. The "alignment" Station and Offset have this parameter but the Structure Labels do not. I need to add that parameter to the options when editing Structure Labels. Example Rotated Grate.JPG
    2015-10
    Central New Jersey
    437
    Offset from an alignment is measured in a perpendicular direction from the alignment ... so wouldn't the offset to the grate simply be an additional amount added to the offset of the structure's insertion point? This additional amount value could be embedded in the structure's definition such that a single label style could work with multiple structure sizes with varying insertion point to grate dimensions.
    2020-12
    4
    The Structure Rotation Angle has to be added to the "perpendicular direction". I've already entered that angle to the expression manually and it works perfectly, but the Structure Label has to have all the information in the style. Hence, I need to grab the "perpendicular direction" of the Structure Offset. Maybe this graphic helps...Example Rotated Grate2.JPG
    2015-10
    Central New Jersey
    437
    How about editing the structure so its insertion point will be located at the point on the grate where you need the station and offset?
    The insert location can be relocated using Partbuilder. Its the Layout Data under Autolayout Data. Right click on it and choose Select Placement Point ...
    2020-12
    4
    Won't work. We have multiple locations for the grate. Both edges of the grate can be the Station location depending on if the structure is rotated 180 degrees. Also, we also need the CENTER of the grate to be on the flowline at times. So essentially we have 4 possible locations for the structure in relation to the flowline. What I need is that "perpendicular direction" parameter, the last piece of this puzzle.
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    8,579
    Is that a label style you are using to label the structure D3 in your earlier post? If so, what type of label is it? Could you share a sample drawing?
  1. 2021: Civil 3D 2021 - Pressure pipe runs
    By jmyers487961 in forum AutoCAD Civil 3D - Pipes
    Last Post: 2020-08-21, 07:46 PM
  2. Alignment Station label that is perpendicular to alignment
    By corboto in forum AutoCAD Civil 3D - Alignments
    Last Post: 2010-05-20, 10:43 PM
  3. Replies: 4
    Last Post: 2009-07-29, 09:43 PM
  4. ENTIDADES EN ALIGNMENT COMO "FIXED", "FLOTING" y "FREE"
    By cadia in forum Español - AutoCAD Civil 3D
    Last Post: 2009-02-01, 04:21 AM
Tags for this Thread
