I'm surprised there aren't more Dynamo threads.... I thought this would be bigger than LISP.
First, I'm a foodservice consultant, not an architect. Most of my Revit wrangling is getting it to do things that it wasn't primarily designed for. I want to use Dynamo much in the same way that I used LISP, write a small routine to automate repetitive tasks with the prime intent of eliminating error.
Much like layers, I find many of our objects on the wrong workset. I find the fastest way is to switch to the home 3D view, select everything, save that selection, and switch back to a much less intensive view. Then, I reload that selection set, use the filter to select categories of objects, change their workset, and repeat. I also saw an out-of-date Dynamo package that even created a set of worksets based on a list. This only needs to be done once a project, so i'm less concerned with that automation.
Does anyone know what command, or how to write one, that can filter a selection set based on category then assign a workset?
Thanks in advance for any advice
stu
