Thread: Filter type and Filter data is not working
    2011-08
    Vadodara, India
    147
    Default Filter type and Filter data is not working
    Hi!
    I want to select only Lines but filter type and data is not working. it says invalid filter type
    setColl = AcadDoc.SelectionSets
            For Each objSSet1 In setColl
                If objSSet1.Name = setName Then
                    AcadDoc.SelectionSets.Item(setName).Delete()
                    Exit For
                End If
            Next
            objSSet1 = AcadDoc.SelectionSets.Add(setName)
            'End With
            Me.Hide()
            Dim FilterType(0) As Integer
            Dim FilterData(0) As Object
            FilterType(0) = 0
            FilterData(0) = "Line"
            objSSet1.SelectOnScreen(FilterType, FilterData)
    Can any one help me.
    Last edited by Opie; 2021-01-07 at 01:38 PM. Reason: [code] tags improve readability
    6,475
    Default Re: Filter type and Filter data is not working
    Here's a C# example of how to do it using the managed api. Note that the SelectAll method accepts a single array.
                // Get a selection set of ents whose color is not ByLayer.
                TypedValue[] tvls = new TypedValue[2];
                tvls.SetValue(new TypedValue((int)DxfCode.Operator, "!="), 0);
                tvls.SetValue(new TypedValue((int)DxfCode.Color, 256), 1); //Color 0 = ByLayer
                SelectionFilter sf = new SelectionFilter(tvls);
                PromptSelectionResult PSR = Active.Editor.SelectAll(sf);
    If you still want to use the COM method, the example in this Help topic filters for a circle. Note that the Select method takes variant arrays, so you have to assign your filter data to variant arrays first before trying to use it in the Filter argument.
    BTW, to put your code in a CODE window, click on the Go Advanced button, then select the # button to insert CODE tags.
    LinkedIn
  1. 2019: when set up a structure column schedule, Why the Field "Type" is not in the filter list?
    By 1143413815422067 in forum Revit Architecture - General
    Last Post: 2018-09-29, 01:38 AM
  2. Replies: 0
    Last Post: 2017-06-15, 07:31 PM
  3. 2014: Floors and view filter not working as expected
    By david_peterson in forum Revit Architecture - General
    Last Post: 2014-05-06, 03:52 PM
  4. Not able to choose my custom filter system type!!??
    By ncostab in forum Revit MEP - General
    Last Post: 2010-03-19, 04:21 PM
  5. Point (co-ordinate) filter not working as expected
    By sarahjane in forum AutoCAD General
    Last Post: 2005-11-15, 06:59 PM
