Thread: Alert Boxes
    2006-10
    6
    Question Alert Boxes
    Hi, well I thought I know my stuff pretty well. I use alert boxes in a number of my lisp routines, Just today my alert box stopped showing up. The results of the alert will echo to the command prompt but the actual alert box does not show up. Filedia, Cmdecho, Cmddia are set appropiately. Never happened in all my years. Thanks for any advice.
    Certifiable AUGI Addict
    2001-03
    Tallahassee, FL USA
    3,667
    3
    Default Re: Alert Boxes
    Check the system variable QAFLAGS, if set to 4 Alerts will display at the command prompt.
    Setting it to the default of 0 should fix it.
    It affects a lot of commands so if you're using it in lisp routines it's best to reset it to 0 on exit or error.
    2006-10
    6
    This worked, thank you so much, it makes sense now. I am working on some new routines and wouldn't have known this, however, to save time I did go online and try to pull some parts out of other routines. I am self taught at lisp and vla concepts so it would have taken me forever to trouble shoot this one. Thank you again and great skill.
    Jim
    2001-03
    Tallahassee, FL USA
    3,667
    Glad I could help, good reference for the undocumented stuff here: http://www.manusoft.com/resources/acadexposed.html
  1. Replies: 1
    Last Post: 2017-04-15, 03:28 PM
  2. Polygonal scope boxes or 4 point scope boxes with angles unequal 90 degrees
    By Wish List System in forum Revit Structure - Wish List
    Last Post: 2013-04-10, 01:19 AM
  3. Highlighting and Alert Boxes
    By lance.81922 in forum AutoLISP
    Last Post: 2005-02-19, 04:33 PM
  4. AutoCAD alert boxes.
    By peter.woodcock in forum AutoCAD General
    Last Post: 2004-11-11, 05:27 PM
