Thread: Tab key cycles selection
    Wish List Administration
    2011-08
    4,581
    Default Re: Tab key cycles selection
    Summary: Pressing Tab key cycles selection for object to be selected
    Description: Revit has a feature whereby pressing the tab key cycles through objects that will be selected. If something similar can be implemented in AutoCAD especially when there are overlapping lines. Current methodology is to highlight both then deselect the line not needed.
    Product and Feature: AutoCAD - User Interface
    Submitted By: wrmarshall on 01/11/2021
    Cairo - no, not Illinois
    5,069
    Turn on SelectionCycling, only pick the one you want. no need for 'Tabbing' as a better method is already in the software
    Earth
    9,805
    Yeah - that is the way it used to work before Selection Cycling
    At some point post that addition, I'm pretty sure you could still use Ctrl to cycle though, but now I'm not sure.
    Check into LEGACYCTRLPICK and SUBOBJSELECTIONMODE
    R.K. McSwain | CAD Panacea |
    Certifiable AUGI Addict
    2001-03
    Tallahassee, FL USA
    3,667
    As I don't need it very often I leave Selection Cycling off.
    I can hover over a line and use Shift+Spacebar to cycle display of each line but cannot see the layer until I select one.
    If I thought I'd use it more than once every few months I'd turn Selection Cycling on.
    2011-08
    4,581
    Exclamation Re: Tab key cycles selection
    This wish has been reported as granted and already in the software.
