Thread: Simplified 3D-to-2D Conversion
    2012-04
    9
    Default Simplified 3D-to-2D Conversion
    I mostly work in 2D (AutoCAD LT 2015), but manufacturers typically provide downloadable product drawings in 3D, usually in a wireframe format, sometimes as surfaces.
    I need to be able to convert these 3D drawings to simple left/right, front, top 2D views without all of the extraneous lines – just an accurate to-scale outline/representation (definitions of the visible edges) of the components (as though I had drawn them from scratch with simple lines, arcs, chamfers, fillets, etc., by taking physical measurements).
    I have access to full-blown AutoCAD 2017, but am not 3D-savvy. I have experimented with FLATSHOT and other 3D-to-2D methods, but have yet to get the results I’m looking for. What I typically end up with are “zero-Z” views with hundreds or thousands of tiny lines that look like a giant jig-saw puzzle (or an over-the-top game of pick-up sticks).
    Can someone please help me with a list of the sequential steps (with commands and relevant settings) to go from a 3D drawing (either wireframe, or surfaces, or both), to simple 2D views (sans hidden lines), such as described above? I have attached a sample drawing that I recently tried to simplify, but ended up getting frustrated.
    5,917
    Default Re: Simplified 3D-to-2D Conversion
    I'm not sure what you want to do with the 2D views. In the attached file, I just made paperspace viewports and set the display style to 3D HIDDEN.
  1. Making Road corridor simplified way
    By ljupadhyay in forum Civil 3D - Civil Design Companion - General
    Last Post: 2019-10-24, 09:10 AM
  2. Simplified Assembly Representations
    Last Post: 2012-09-03, 02:46 PM
  3. Simplified Generation of iAssemblies
    Last Post: 2007-05-17, 05:27 PM
  4. Simplified version of Quick Select.
    By caduzer in forum AutoCAD Customization
    Last Post: 2006-12-04, 07:32 PM
  5. Simplified Line Keyboard Shortcuts
    By Scott Hopkins in forum Revit Architecture - Tips & Tricks
    Last Post: 2003-07-24, 06:05 PM
