Thread: HELP ME ! ADDING LAYER BOUNDARY RECTANG IS WALL AND LAYER HATCH IS HATCH
    2020-04
    4
    Unhappy HELP ME ! ADDING LAYER BOUNDARY RECTANG IS WALL AND LAYER HATCH IS HATCH
    (defun C:PZ ();
    (setq pnt1 (getpoint "Select upper left hand corner for placement of rectangle: "))
    (setq pnt2 (getcorner pnt1 "Select lower right hand corner for placement of rectangle: "))
    (command "rectangle" pnt1 pnt2)
    (setq ent1 (entlast))
    (command "-hatch" "P" "ANSI31" "1000" "0" "S" ent1"" "")
    Last edited by Opie; 2021-01-20 at 01:46 PM. Reason: [code] tags added for improved readability
    Certifiable AUGI Addict
    2001-03
    Tallahassee, FL USA
    3,667
    Default Re: HELP ME ! ADDING LAYER BOUNDARY RECTANG IS WALL AND LAYER HATCH IS HATCH
    2005-06
    in the upper right corner
    3,507
    Quote Originally Posted by Long Park View Post
    (defun C:PZ ();
    Give this a whirl..
    (of course you would need to edit the properties of those layers you mentioned, I used layer colors I use a lot)
    (defun C:PZ (/ lyr LR1 LR2 ent1);
    (setq lyr (getvar "clayer"))
    	(setq LR1 (tblsearch "layer" "WALL"));;checks to see if the layer exists already
    	(setq LR2 (tblsearch "layer" "HATCH"));;checks to see if the layer exists already
    		(if (= LR1 nil)
    		(command "layer" "make" "WALL" "color" "3" "" "" "" "")) ;;edit for your desired layer properties
    		(if (= LR2 nil)
    		(command "layer" "make" "HATCH" "color" "150" "" "" "" "")) ;;edit for your desired layer properties
    (command "layer" "s" "WALL" "" "")
    (command "layer" "s" "HATCH" "" "")
    (setvar "clayer" lyr)
    (princ)
    Hope this helps.
    It was nice that you had a starting point to help you with.
    A few etiquette hints, please don't use UPPERCASE letters when posting questions, or explanation points (!), it comes across as shouting a demand, not a request.
    Also the thread title should just state it's purpose "please help with wall and hatch lisp" or similar, and then describe your issues in the body of the thread.
    2003-07
    560
    Nice idea tedg for me if making a lot of lisps then I have a Autoload lisp and one of the defuns in it is laychk it does as it suggests does layer exist if not then make. So 1 line in code.
    (laychk "Abcdefg" 3 "Continous") or a simpler version that ignores color and line type (laychk1 "Abcdefg") and (laychk2 "Abcdefg" 3).
  1. use rectang to form leadline.
    By 742850517357521 in forum AutoLISP
    Last Post: 2015-11-03, 11:13 AM
  2. Replies: 0
    Last Post: 2008-02-27, 10:08 PM
  3. Retain Hatch boundaries, not adding boundary
    By elaynemaydesign in forum AutoCAD General
    Last Post: 2006-05-15, 06:59 PM
  4. Select Hatch and Hatch Boundary as same time
    By pangell in forum AutoCAD General
    Last Post: 2006-04-19, 07:42 PM
  5. Rectang "Unknown command"
    By cpercy in forum AutoCAD General
    Last Post: 2005-06-06, 04:11 PM
