Results 1 to 10 of 12
Thread: Display a list of customized templates to choose from
    2003-12
    45
    Question Display a list of customized templates to choose from
    Is there a way to create/add a dialogue box similar to the default template drop down selection (or modify the default) to display a list customized templates to choose?
    9,805
    Default Re: Display a list of customized templates to choose from
    That list is showing you the templates in the path you have chosen/set in Options.
    Options > Files > Template Settings > Drawing Template File Location.
    Change this, restart AutoCAD.
    6,420
    Or you can copy your templates to AutoCAD's template folder. I prefix mine with an underscore so that they appear at the top.
    LinkedIn
    9,805
    Technically that will work, but I prefer and always advise keeping your own custom files separate from Autodesk's files.
    Then when you install a new version or move to a new PC, all of your custom files are in one place, and you simply have to re-map the pointers inside of AutoCAD (which can be automated).
    2003-12
    45
    Thanks for the feedback. That is what i was trying to achieve.
    Tallahassee, FL USA
    3,667
    Quote Originally Posted by gcameron View Post
    I added a drop-down list of customized templates to a custom panel in the Ribbon for them with macros like
    ^C^C^P(vla-activate (vla-Add (vla-get-Documents (vlax-get-acad-object)) (strcat (getvar "localrootprefix") "template" (chr 92) "AutoCAD Template" (chr 92) "FL83-NF.dwt")))
    to create new drawings from custom templates for different workflows. I use (chr 92) for "\\" as it works in macros the same as if the code was pasted to the command line making it easy to test before adding to a macro.
    6,420
    Yeah, I suppose that is good advice for users who need their own custom templates. I supply our users with standards templates and I have a system for keeping them updated, so I just copy them to the template folder.
    An old trick for including custom templates in the default template folder is to put a shortcut in that folder which points to the custom folder. AutoCAD treats it like a subfolder. That way you can use stock templates and have quick access to custom templates.
    LinkedIn
    2015-11
    Highlands ranch, CO
    29
    to create new drawings from custom templates for different workflows. I use (chr 92) for "" as it works in macros the same as if the code was pasted to the command line making it easy to test before adding to a macro.
    This is a great tip Tom (chr 92).
    Got any other Macro tips to share?
    ~Greg
    5,719
    I agree and do this for everything I can as well.
    Do you happen to know if "Map - North Arrows.dwg" and "Map - Scale Bars.dwg" are no longer hard-coded into Civil 3D?
    C:\Program Files\Autodesk\AutoCAD 202X\Map\Sample\Symbols
    We've always had to overwrite those with our own (make a .bak of original) to get them to show up in Layout Tools ribbon tab, no?
    Tallahassee, FL USA
    3,667
    Quote Originally Posted by greg.battin View Post
    ~Greg
    About Special Control Characters in Command Macros is a good reference for creating Macros. I've added way too many to custom Ribbon panels, tabs, and Shortcut Menus to list. I prefer to use Shortcut Menus for modifying objects since they're accessible with a right-click instead of looking for an icon to pick. To Customize a Shortcut Menu explains OBJECT_objectname or OBJECTS_objectname but refer to Shortcut Menu Aliases for blocks and external references (xrefs).
  1. Replies: 0
    Last Post: 2014-11-30, 01:16 PM
  2. 2014: Setting Up Project Templates & View Templates???
    By sbrennan in forum Revit MEP - General
    Last Post: 2013-08-29, 09:17 PM
  3. Replies: 0
    Last Post: 2011-12-09, 02:57 PM
  4. View Filters and view Templates... But not View Templates
    By saeborne in forum Revit Architecture - General
    Last Post: 2010-09-13, 04:40 PM
  5. Revit architecture view templates or Revit Structure view templates
    By rob.127056 in forum Revit Architecture - General
    Last Post: 2009-02-13, 07:56 PM
