I can't figure out how to fix this. see image
my corridor looked fine, but the surface is not working out so good.
any ideas on how to fix this?
thanks
thanks
Do you have the breaklines option checked when creating the surface from the corridor?
Or can you show what your assembly looks like?
I first built a corridor with just the lanes for the entire length of the alignment.
then I built a corridor surface for that.
then I created the medians in two halves, pulled profiles from the corridor surface.
then I built a new corridor with the attached assembly. the corridor looks great.
but when I create the corridor surface with top links (breakline option checked) I get want you see in the below image.
I also tried adding top curb and flowline breaklines as well but that didn't help.
thanks
Let me make sure I understand you.
You have two corridors and associated surfaces. The first corridor is the lanes without the island. You have a surface associated with that. The second corridor and surface is the island based off of profiles from the surface of the first corridor.
How does the second corridor surface appear? Does it look as expected alone?
I'm not seeing where you have any surface attached to your curb assemblies from the back of curb to the center of the island.
Are you pasting the two surfaces into another surface?
I created the first surface for the sole purposed of pulling profiles for the island alignments. Once that was done I froze that surface and corridor.
then i created my second corridor using the 2 subassemblies from below. the surface shown below if from this second corridor.
I haven't connected the 2 curb assemblies yet. do you think the is the issue?
no pasting is involved, both are independent of each other.
Can you post a sample drawing? We could go back and forth with questions and answers that may be found in a drawing.
Otherwise, is this one or two alignments for the curb assemblies? It appears to be two alignments based on the appearance of the assemblies.
the drawing is over 3 megs. not sure if that can be uploaded
