Thread: Paper Space layout
    2009-11
    Raleigh, NC
    937
    Default Paper Space layout
    I Copied and Pasted our title block from one file to another to Original Coordinates.
    Plotter and layout parameters in plot dialogue box are the same.
    How can I set 0,0 in Paper Space so this can be consistent in older drawings?
    Super Moderator CAtDiva's Avatar
    2015-10
    Where pedals spin to move wheels
    441
    Default Re: Paper Space layout
    What is your "Plot area" set to? If it's set to Layout, then it will default to the last successful plot layout regardless of where 0,0 is. I generally recommend either Extents (if you don't have linework/annotation outside the limits of your titleblock) or Window (if you do). Using Window will be relative to the coordinate system, so if the titleblock is always at the same place (recommend 0,0), then the window will be consistent.
    Certifiable AUGI Addict
    2001-03
    Tallahassee, FL USA
    3,658
    Importing a layout with the title block from a template file avoids issues like you're having.
    I use macros like:
    (Steal (strcat (vl-filename-directory (getenv "QnewTemplate")) (chr 92) "AutoCAD Template" (chr 92) "Templates.dwt") (list (list "Page Setups" (list "11×17" "11×17 PDF"))(list "Layouts" (list "11×17")))) .regen
    using Lee Mac's Steal From Drawing lisp to bring in both Page Setups for both plotting hardcopy or PDF along with the Layout.
    Lee explains how to use it in the link but if you need help writing the macro I could help. I load the function in acaddoc.lsp as I use it for many things.
    Basically (Steal "filename with path" then (List of (Lists of types of things you want to steal with a (List of their names)))).
  1. Medir em Paper Space depois alterar a escala no Layout
    By fgoleite in forum AutoCAD General
    Last Post: 2011-11-11, 07:20 AM
  2. Exporting a Revit sheet to AutoCAD layout (paper space)
    By colnagoboy in forum Revit Architecture - General
    Last Post: 2010-03-21, 03:31 PM
  3. Invisible Layout / Paper space
    By artisteroi in forum AutoCAD General
    Last Post: 2008-07-30, 05:04 AM
  4. Replies: 3
    Last Post: 2006-10-24, 07:05 PM
  5. xref file not visible on layout paper space
    By drafting.82475 in forum AutoCAD General
    Last Post: 2005-06-10, 08:34 PM
