Thread: Structures Settings
    2017-03
    20
    Default Structures Settings
    I am using the smallest part available (15 x 15 Rect Structure 24 dia Frm 4 FmHt 2 Slab 3 Wall 4 Floor) without creating anything new. It appears that what I will call a wipeout, for a manhole makes the pipes look like they don't connect. The label does list all inverts, but it appears to end 2'-3' away from the structure. Where might this setting be?
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,103
    Default Re: Structures Settings
    What does it look like in a 3d isometric view? Have you modified the connection point of the pipes with the structure?
    You could disconnect all pipes from the structure. Then reconnect all the pipes back to the structure (highest invert first). This should put the connection point back to the center or insertion point of the structure.
  1. 2021: nvidia control panel - manage 3d settings; recommend settings
    By bensal in forum Revit - Hardware & Operating Systems
    Last Post: 2020-09-07, 01:12 PM
  2. 2012: Make existing dimension settings my current dimension settings
    By cfalcionesr in forum AutoCAD General
    Last Post: 2012-08-02, 05:23 PM
  3. Sun settings VS realtime view settings
    By Maximillian in forum Revit Architecture - General
    Last Post: 2006-11-22, 05:54 PM
  4. Tensile Roof Structures
    By Steve_Stafford in forum Revit Architecture - General
    Last Post: 2003-12-12, 04:47 AM
  5. Visibility of Level Lines for Different Structures
    By Henry D in forum Revit Architecture - General
    Last Post: 2003-06-02, 03:31 PM
