Results 1 to 7 of 7
Thread: My reliable Insert Layers LISP needs help
    2018-03
    4
    Default My reliable Insert Layers LISP needs help
    Team,
    I have a LISP I was given on these forums way back in 2009 or so that would insert layers into a drawing from a template.
    But now in my new position it doesn't want to work in our network infrastructure...
    The original code is
    ;ILAYER - INSERTS DEFAULT LAYERS INTO A DRAWING
    (defun C:iLayer ( / template random)
    (setq template "\\xxx-server\data\user_redirects\myname\Documents\4 xxx CAD Library\Templates\Layers\Layers.dwt")
    (setq random (strcat (vl-filename-mktemp) ".dws"))
    (vl-file-copy template random)
    (command "._Insert" (strcat "*" random) (list 0 0 0) "1.0" "0.0" )
    Any time I run it I receive errors like this:
    Command:
    Command: ILAYER
    ._Insert Enter block name or [?]: *C:\Users\myname\AppData\Local\Temp\$VL~~001.dws
    "$VL~~001.dws": Can't find file in search path:
    \\xxx-server\data\user_redirects\myname\Documents\ (current directory)
    \\xxx-server\data\user_redirects\myname\Documents\Z CAD Support Files\
    \\xxx-server\data\user_redirects\myname\Documents\Z CAD Support Files\Lisps\
    \\xxx-server\data\user_redirects\myname\Documents\4 CTCI CAD Library\
    C:\Users\myname\AppData\Roaming\Autodesk\AutoCAD 2021\R24.0\enu\support\
    C:\Program Files\Autodesk\AutoCAD 2021\support\
    C:\Program Files\Autodesk\AutoCAD 2021\support\en-US\
    C:\Program Files\Autodesk\AutoCAD 2021\fonts\
    C:\Program Files\Autodesk\AutoCAD 2021\Express\
    C:\Program Files\Autodesk\AutoCAD 2021\support\color\
    C:\Program Files (x86)\Autodesk\ApplicationPlugins\Autodesk AppManager 2020-2021.bundle\Contents\Windows\
    C:\Program Files (x86)\Autodesk\ApplicationPlugins\Autodesk AppManager 2020-2021.bundle\Contents\Windows\2021\
    C:\Program Files (x86)\Autodesk\ApplicationPlugins\Autodesk FeaturedApps 2020-2021.bundle\Contents\Resources\
    C:\Program Files (x86)\Autodesk\ApplicationPlugins\Autodesk FeaturedApps 2020-2021.bundle\Contents\Windows\2021\Win64\
    C:\Program Files (x86)\Autodesk\ApplicationPlugins\Autodesk QRCodes 2020-2021.bundle\Contents\Windows\2021\win64\
    C:\Program Files (x86)\Autodesk\ApplicationPlugins\Autodesk QRCodes 2020-2021.bundle\Contents\Resources\
    C:\Program Files\Autodesk\AutoCAD 2021\drv\
    *Invalid*
    ; error: Function cancelled
    Command:
    Any ideas?
    Thx,
    Red
    2003-07
    555
    Default Re: My reliable Insert Layers LISP needs help
    try (setq template "\\\\xxx-server\\data\\user_redirects\\myname\\Documents\\4 xxx CAD Library\\Templates\\Layers\\Layers.dwt") spaces in directory name can do some funny things.
    2003-07
    555
    Also as you have paths set why not just (command "-insert" "layers.dwt" ............ no need to copy
    Certifiable AUGI Addict
    2001-03
    Tallahassee, FL USA
    3,658
    FYI: If any of the layers already exist in the drawing importing a template will not update the layer properties like importing and restoring a Layer State would.
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,096
    Quote Originally Posted by BIG-AL View Post
    I'm not sure it was the spaces, but more so with the single backslashes. AutoLISP requires backslashes to be escaped in strings. The escape character just so happens to be a backslash. To get a single backslash in a string, one would need to double all backslashes in their code.
    2018-03
    4
    Thanks I updated to try that with no luck
    - - - Updated - - -
    Thanks Tom good point to remember, but these are files from others we are updating and have to add our layers to them before we start our work.
    - - - Updated - - -
    Opie, I believe you actually helped me set up this LISP way back.
    - - - Updated - - -
    Hold it!
    I followed Big Al's update and then had a PEBCAK issue... seems to be working now!
    Thank you all once again for saving my butt!
    2001-03
    Tallahassee, FL USA
    3,658
    Quote Originally Posted by GFournier301 View Post
    - - - Updated - - -
    You would have to save the layer state from the template removing the layers you don't want first, then bringing them in to the current drawing and making sure the layer settings are correct with lisp is a snap.
    layerstate-import (AutoLISP)
    https://help.autodesk.com/view/ACD/2...1-2CEA0C21EA1B
    Never mind don't do that! Been a while but you need to use the dialog box for importing layer states to have the option to not turn off layers not included in the layer state.
  1. Can ramp be reliable for construction?
    By Alvin_Alejandro in forum Revit Architecture - General
    Last Post: 2012-07-05, 03:30 AM
  2. Replies: 7
    Last Post: 2008-12-22, 07:51 PM
  3. Provide a More Reliable Drawing Recovery Tool
    Last Post: 2008-01-10, 08:07 PM
  4. Reliable hatch patterns
    By Wagurto in forum Revit Architecture - General
    Last Post: 2004-08-05, 06:55 PM
  5. How reliable are recovery files?
    By david1803 in forum Revit Architecture - General
    Last Post: 2003-10-30, 02:00 AM
