Thread: Change ACAD 2017 default Annotation color in .DWT
    2006-10
    Michigan USA
    Default Change ACAD 2017 default Annotation color in .DWT
    I haven't been on Autocad in a very long while, I do most all of my design work in SolidWorks, and back where I used to work we had a autolisp for changing annotation text color. I have been screwing around
    with it for way too long and can't figure out how to change the default text color and have it automatically put it on its own layer and set it in the .DWT so I can forget about it.
    Clicking text and having to change it in properties is a pain and having to change layers every time I want to enter text is BS as well. Any suggestions would be
    awesome!!!
    Tallahassee, FL USA
    3,665
    Default Re: Change ACAD 2017 default Annotation color in .DWT
    In AutoCAD it's frowned on to set properties to any objects other than ByLayer. That makes controlling how or if objects are displayed easily set up in each viewport. Fortunately anyone receiving one of your drawings could easily set every object you assigned properties to back to ByLayer with the SETBYLAYER command. https://help.autodesk.com/view/ACD/2...4-506C6B792E9E
    In newer versions you can set what layer new text will be placed on. https://knowledge.autodesk.com/suppo...2DD06-htm.html
    Lee Mac has lisp you can use that determines what layers new text or other object types will be placed on using reactors. http://www.lee-mac.com/layerdirector.html
  1. Default AutoCAD 2017 plot color lineweights
    By Greymoire in forum CAD Standards
    Last Post: 2017-03-16, 06:56 PM
  2. Revit DWG Export Function and Acad .dwt source?
    By dlevesque in forum Revit - API
    Last Post: 2011-09-06, 07:44 AM
  3. Issues with .dwt files created in 2010 being compatible with ACAD '09
    By sean.round in forum AutoCAD Civil 3D - General
    Last Post: 2010-10-25, 03:44 PM
  4. Screen color vs Print Color vs Screen Color
    By bwiab in forum Revit Architecture - General
    Last Post: 2009-04-27, 02:22 PM
  5. Acad-A_Title.dwt in Lt 2004
    By heronworks in forum AutoCAD LT - General
    Last Post: 2005-04-28, 02:55 AM
