Re: Option to turn off graphics overrides by discipline
Summary: There should be an option to turn off architectural transparency or any graphical overrides for MEP views.
Description: It's cool that Autodesk thinks that MEP has superpowers and can see through walls but it's not true. In the MEP sections or roof plans I see through walls and roofs. This makes the view cluttered and hard to understand since walls and roofs are an important part of the building. If there is ductwork above the roof I should be able to see it but not after it goes below. If I can see the ductwork that is below the roof wouldn't I think it is above the roof because I can see it. It is possible to use another discipline but then MEP functionality is turned off.
Product and Feature: Revit MEP - Other
Submitted By: montykymyers on 03/06/2021
- You may not post replies
- You may not edit your posts
Forum Rules
