Thread: Setting dimension offset
    2014-04
    39
    Default Setting dimension offset
    When dimensioning around a dwelling, where parts of the house protrude out, I want to set the dimension offset to a specific distance from the protrusion is there any way to do this quickly. If I set the offset to 1200mm this will not be even across different protrusions, is there any way to draw a line across all the dimensions and the offset is set to this adjusting the offset for the dimensions independant of any protrusions to look even throughout the length of the line of dims.
    Cairo - no, not Illinois
    5,069
    Default Re: Setting dimension offset
    try using DIM CONTINUE after you have the first dimension line at the distance you want
    2014-04
    39
    using dim continue keeps the dimension in a straight line but draws the line to where is picked less the line offset. What I am after is the line offset stays the same length regardless what is picked, to keep the dimension uniform at a regular offset? is there any other way to do it.
    in the upper right corner
    3,507
    Quote Originally Posted by cjharley1450642179 View Post
    If I understand what you want, I don't know of a setting for that, Acad wants to snap to an object.
    The quickest way to do what you want (in my opinion) is do the dim-continue, and then isolate your dimension layer and stretch the ends to where you want.
    AUGI Addict madcadder's Avatar
    Too far from the beach
    1,054
    All my dimensions are in PS, so I just drop an XLINE on the outermost point and then offset it .25, offset again, and again (or however many times I will need), and erase the original.
    When I stretch a dim it goes out to one of those XLINEs.
    It's not simple, but it does make clean, uniform dimensions.
    1,054
    After revisiting this I see better what you are trying to do. And it is similar to what I suggested, but takes more prep.
    Again... All my dims are in PS. They all start .25 off the outmost line. But...
    I have my dimstyle set to "Fixed length extension lines", I have the length set to .1875.
    I also have the "Extend beyond dim lines" set to .0625.
    And "Offset from origin" set to .0625.
    So, every dim placed has the gap of .0625 and an .1875 line. By doing so, when I place another dim farther out...it also has the .1875 length line that lines up with the .0625 "extend beyond..." of the line.dimstyle.PNG
  1. 2011: label points at an offset from alignment showing stat, offset, and description
    By mw156 in forum AutoCAD Civil 3D - Survey
    Last Post: 2016-09-29, 06:10 PM
  2. 2015: Unable to offset a spline the has already been offset.
    By crullier in forum Inventor - General
    Last Post: 2014-12-19, 07:39 AM
  3. Pipe Filter by level offset - Reference Level Offset
    Last Post: 2013-04-02, 04:05 AM
  4. Capable of setting dimension on Offset.
    By Wish List System in forum Inventor Wish List
    Last Post: 2012-11-14, 02:44 PM
  5. Replies: 0
    Last Post: 2011-10-11, 08:38 AM
