Thread: Autoload code for non-command functions
    Certifiable AUGI Addict
    2001-03
    Tallahassee, FL USA
    3,667
    Default Autoload code for non-command functions
    I use a lot of lisp in macros with arguments like:
    ^C^C^P(or NewStyle (load "NewStyle.lsp"))(NewStyle "Arial" "arial.ttf")
    As they're not functions that can be entered at the command line without enclosing them in parenthesis () with arguments I cannot simply use the autoload (AutoLISP) function to load NewStyle.lsp.
    Does anyone have code that would autoload NewStyle.lsp and run the code (NewStyle "Arial" "arial.ttf") allowing me to shorten that macro to:
    ^C^C^P(NewStyle "Arial" "arial.ttf")
    It would allow me to clean up a lot of macros.
    2009-11
    5,719
    Default Re: Autoload code for non-command functions
    You could use a dummy Command to Autoload different groups of LISP Functions.
    Say your NewStyle function was part of group of various Style-related functions, you'd Autoload the dummy Command and include that Command call in your macros.
    AcadDoc.lsp:
    (autoload "MyStyles.lsp" '("LoadMyStyles"))
    MyStyles.lsp:
    (defun c:LoadMyStyles ()
         (defun NewStyle (name font / ) ())
         ;;<-- others as needed
         (princ)
    Macro:
    ^C^C^PLoadMyStyles;(NewStyle "Arial" "arial.ttf")
    This would allow you to launch a session without LOADing a bunch of code up front, but would Autoload several functions when the dummy Command is invoked the first time... You can break it up into as many (or as few) groups as you want to minimize the overhead
    HTH
    Computer Specs:
    2001-03
    Tallahassee, FL USA
    3,667
    Sorry I didn't describe that as well as I should have. Busy at work today but needed to tweak a few macros.
    I wasn't really thinking of the autoload function exactly, just wanted to shorten all those macros without adding autoload code for every one of them.
    A "L&Run" lisp function that with the macro:
    ^C^C^P(L&Run "NewStyle" "Arial" "arial.ttf")
    would load "NewStyle.lsp" if needed then run
    Much of the code I have has the same filename as the function. Some macros that call out multiple lisp functions to get something done can be rather large.
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,106
    Spitballing here.
    Maybe change the arguments to your "NewStyle" command into a list would allow the L&Run routine to have a consistent two argument list.
    (defun L&Run (Func Args /)
      (if (or (car (atoms-family 1 (list Func)))
    	  (and
    	    (findfile (strcat Func ".lsp"))
    	    (load (findfile (strcat Func ".lsp"))
    		  "\nUnable to find file."
        (apply (read Func) Args )
    (L&Run "NewStyle" '("Arial" "arial.ttf"))
    Modify to fit your circumstances.
  1. How autoload subroutines code
    By marco_antonio-77339780 in forum AutoCAD Customization
    Last Post: 2019-03-25, 04:24 PM
  2. Replies: 0
    Last Post: 2012-11-24, 07:38 PM
  3. AutoLOAD? From where?
    By methost in forum AutoCAD General
    Last Post: 2005-02-01, 08:10 PM
  4. error: no function definition: AUTOLOAD
    By dalej_k in forum AutoLISP
    Last Post: 2004-08-11, 11:58 PM
  5. autoload menu
    By inner69923 in forum VBA/COM Interop
    Last Post: 2004-07-16, 01:14 PM
