Thread: Shortcut Warning pop-up
    2003-08
    35
    Default Shortcut Warning pop-up
    I recently updated my AutoCad and get a new warning box when I start AutoCad. It can't find a shortcut (see attached). How do I fix this problem? Or at least get rid of the Warning pop-up
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,106
    Default Re: Shortcut Warning pop-up
    Remove those two links from that directory. Those are intended to point you to the wizard for those items and are dependent on the version of AutoCAD they were created for. They are okay to remove from your network folder.
    2003-08
    35
    Thank you very much. I new there had to be a simple answer. A minor but annoying issue.
    in the upper right corner
    3,508
    I get these too every once in a while, I'm not sure why they get created in our network drive.
    I suspect a user is clicking on something or doing something?
    I just go in a delete it when they pop up, does anyone know how they get created/copied to a network directory?
    2002-01
    jUSt Here (a lot)
    9,106
    Probably from an install.
    2001-10
    Defragging the internets.
    350
    I think it happens when someone uses the Migrate Custom Settings.
  1. Shortcut Menus (pop menus) in partial cuix don't work
    By Big Daddy Wags in forum AutoCAD CUI Menus
    Last Post: 2020-09-01, 02:30 PM
  2. Plotter search shortcut warning
    By The Sweg in forum AutoCAD Plotting
    Last Post: 2009-06-15, 10:50 AM
  3. Pop-top fees?
    By christo4robin in forum Revit - In Practice
    Last Post: 2004-02-27, 02:34 AM
  4. Pop-ups
    By gregcashen in forum Suggestions
    Last Post: 2003-05-16, 01:17 AM
