I recently updated my AutoCad and get a new warning box when I start AutoCad. It can't find a shortcut (see attached). How do I fix this problem? Or at least get rid of the Warning pop-up
Remove those two links from that directory. Those are intended to point you to the wizard for those items and are dependent on the version of AutoCAD they were created for. They are okay to remove from your network folder.
Thank you very much. I new there had to be a simple answer. A minor but annoying issue.
I think it happens when someone uses the Migrate Custom Settings.
