forums795216
You're right. I didn't think of that. He's usually alone. But sometimes he hire someone during the summer. His aerials would be on his own PC, so no bottleneck there. His student would connect over the network though.
He usually link his aerials. Is it possible to integrate the aerials in his C3D file instead? So if he'd move his project files to another PC, the imagery would still be there?
If there is no network/server, or NAS to contend with, then definitely consider using Samsung 970 Pro in lieu of Evo (if single SSD) - a pair in RAID 1 would be even better - just be sure that the aerials are on that disk and not a slower, secondary HDD or SATA SSD, as that would just introduce bottleneck via system bus & lower disk read/write.
Some Civil 3D settings that are often overlooked are:
MAPIOPTIONS Command, General tab, Display Quality == Draft
This is saved to the drawing and can be batch processed via Core Console using this routine and the following Script:
_.imagequality _d
(setvar "FILEDIA" 1)
_.qsave
_.quit
MAPIOPTIONS Command, Memory tab, set Temporary File Location to a folder on fastest drive.
MAPIOPTIONS Command, Memory tab, set Memory Limit to 50-75% of total physical RAM (might consider more than 32 GB in your build)
HTH
