Page 3 of 3 FirstFirst 123
Results 21 to 28 of 28
Thread: Best hardware upgrade for C3D with Aerial Images
  1. #21
    2021-03
    15
    Default Re: Best hardware upgrade for C3D with Aerial Images
    Quote Originally Posted by BlackBox View Post
    MAPOPTIONS Command, General tab, Display Quality == Draft
    MAPOPTIONS Command, Memory tab, set Temporary File Location to a folder on fastest drive.
    MAPOPTIONS Command, Memory tab, set Memory Limit to 50-75% of total physical RAM (might consider more than 32 GB in your build)
    Good day BlackBox.
    I tested those commands in C3D 2018 (cause that's what the client uses right now; I had specify 2021 cause I wanted the new computer to be compatible with it).
    When I type MAPOPTIONS Enter, a menu appears. But there's no General tab and no Memory tab.
    Are those new options in C3D 2021?
    The only thing I could find out was this command:
    imagequality
    d (draft) or h (high)
    Does it do the same thing?
    - - - Updated - - -
    That said, although not listed on the Intel Performance Maximizer site, the i9-11900K does have a download for it here.
    You'll also find Intel XTU app useful.
    Cheers
    Alright. Thanks for the info.
    I guess a little Overclocking wouldn't hurt as we'll have a top Noctua cooling solution, of which we're both FANs!
  2. #22
    2009-11
    5,719
    Quote Originally Posted by forums795216 View Post
    Apologies; there's a typo in my post, the Command should have been MAPIOPTIONS.
    Dilly dilly
    Computer Specs:
  3. #23
    2009-11
    5,719
    Something we're looking at getting this month, that may also be valuable to your client's need to view high-resolution aerials, is the Dell UltraSharp 43" 4K monitor, which is on sale for +/- $700/ea (using business account):
    https://www.dell.com/en-us/work/shop...2789&gclsrc=ds
    Computer Specs:
  4. #24
    2021-03
    15
    Humm... Business accounts seem to give great discounts. I'll check this out. I might get one of those screens for myself.
    About the i9-11900K, I'm not sure anymore. The thermals don't look that good. And the energy consumption don't look that good also : Linus Tech Tips: How far will Intel GO?
    - - - Updated - - -
    I'll have to test those MAPIOPTIONS next time I meet with my customer.
  5. #25
    2009-11
    5,719
    You can have a Dell business account without providing a Federal Tax ID - you just have to then pay tax on top of your discounted items.
    If the client's primary design application is AutoCAD-based (and Civil 3D is), then it is ruled by single-core clock speed. Period.
    Other hardware components are apt variables in the overall result, but the single, greatest dependency is single-core clock speed... And for that, Intel i9-11900K still beats AMD Ryzen 5950X (which is pretty awesome) by 20%:
    https://cpu.userbenchmark.com/Compar...00K/4086vs4110
    Just keep in mind that DDR5 hits the market (soon?).
    Also, those were stress tests - your client is never - repeat, never going to get that level of utilization out of any CPU running AutoCAD-based products.
    That said, always go through and tally up your max power consumption to spec the system unit's power supply... I work in CAD all-day, everyday, so I don't care how much power it draws and will gladly give it more if it would make my machine run faster, because completing work more quickly means I get paid more... When I get paid for consuming less energy, I'll be really good at that instead. Haha
    Cheers
    Computer Specs:
  6. #26
    2021-03
    15
    Apparently Intel has a finite turbo period of 56s by default. So that limits the power consumption. But the finite turbo period can be disabled in the BIOS. That's when the Wattages and temps increases. So if someone doesn't touch the default settings they should be good for that matter. If they want the cpu boost 100% of the time, well they can just make sure the power supply can handle it and have good cooling, I guess.
    From the Asus mobo bios manual: Asus Multicore Enhancement:
    Cheers
    Another good point!
  7. #27
    Cairo - no, not Illinois
    5,069
    So, out of curiosity, what's the FFE of your home?
  8. #28
    2009-11
    5,719
    My home isn't part of this thread ; if it helps, my calculations are intended only to spec the PSU & UPS for servers, network/security equipment and workstations.
    Our workstations have an 850W PSU and 1200W (1440VA) UPS.
    Cheers
    Computer Specs:
  1. help user upgrade from c3d 16 to c3d 17
    By geofras106693 in forum CAD Management - General
    Last Post: 2017-01-23, 07:48 PM
  2. loading Aerial images hang up my machine!!!
    By leland.morine901495 in forum AutoCAD Civil 3D - General
    Last Post: 2012-01-03, 10:20 PM
  3. Hardware Revit UI and Hardware Acceleration - Maxi Vista
    By 3dway in forum Revit - Hardware & Operating Systems
    Last Post: 2010-10-12, 09:18 PM
  4. Oblique Aerial Images
    By trconnet in forum Raster Design - General
    Last Post: 2008-06-01, 11:04 PM
  5. Replies: 2
    Last Post: 2006-07-18, 10:43 PM
