Results 1 to 9 of 9
Thread: How to set the Point Style for a Civil 3d Cogo Point?
    2003-11
    450
    Default How to set the Point Style for a Civil 3d Cogo Point?
    How can I set the point style for a Civil 3d Cogo Point? I am currently copying the style from another point but I would rather not do this because the style may not be assigned to point when I first use the lisp.
    If I do a dump I can see the name of the style is #<VLA-OBJECT IAeccPointStyle 00000243056af840>
    How do I set VLA_OBJECT... to a variable?
    (defun c:pm_two_arrow (/)
        (initerr)
        (vl-load-com)
        (setq acaddocument (vla-get-activedocument (vlax-get-acad-object)))
        (setq mspace (vla-get-modelspace acaddocument))
        (setq sourcept (vlax-ename->vla-object (car (entsel "\nSelect Source Survey Point: "))))
        ;;I would like to remove the line below
        (setq destpt (vlax-ename->vla-object (car (entsel "\nSelect Destination Survey Point: "))))
        (setq pt1 (getpoint "\nPick Point 1 for Rotation: "))
        (setq pt2 (getpoint "\nPick Point 1 for Rotation: "))
        (setq ang (angle pt1 pt2))
        (setq ptstyle (vlax-get sourcept 'Style))
        ;Style = #<VLA-OBJECT IAeccPointStyle 00000243056af840>
        ;(setq new_pt_style ())
        ;(vlax-put pt 'Style ptstyle)
        (vlax-put-property destpt 'Style ptstyle)
        (vlax-put-property destpt 'Rotation ang)
        (reset)
        (princ)
    (princ)
    2003-07
    561
    Default Re: How to set the Point Style for a Civil 3d Cogo Point?
    Here is a start and may be helpfull.
    HTML Code:
    ; create civ3d points example
    ; By Alan H 2019
    (vl-load-com)
    (if (not AH:vercheck)(load "vercheck"))
    (ah:vercheck)
    (defun c:psty ( / sty num ptnum ss x )
    (setq sty (getstring "\nEnter new style name "))
    (while (setq ss (ssget (list (cons 0 "Aecc_Cogo_point"))))
      (repeat (setq x (sslength ss))
        (setq obj (vlax-ename->vla-object (ssname ss (setq x (- x 1)))))
        (setq ptnum  (vlax-get obj 'Number))
        (vlax-for Point (vlax-get-property *aeccDoc* "Points")
          (setq num  (vlax-get point 'Number))
          (if (= num ptnum)
            (vlax-put-property Point 'Style sty)
    ; vercheck.lsp  version check for *aecc objects
    ; By Alan H
    (defun ah:vercheck ( / vrsn appstr)
    (vl-load-com)
    (setq acApp (vlax-get-acad-object))
      (setq	C3D (strcat "HKEY_LOCAL_MACHINE\\"
    		    (if	vlax-user-product-key
    		      (vlax-user-product-key)
    		      (vlax-product-key)
    	C3D (vl-registry-read C3D "Release")
    	C3D (substr
    	      C3D
    	      (vl-string-search "." C3D (+ (vl-string-search "." C3D) 1))
    (setq *AeccDoc*(vla-getinterfaceobject
    			(strcat "AeccXUiLand.AeccApplication." C3D)
    (princ)
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,106
    You would need to query the PointStyles property of the Civil 3D document for the point style you are wishing to use.
    2003-07
    561
    Like Opie 'PointlabelStyles
    2002-01
    jUSt Here (a lot)
    9,106
    Quote Originally Posted by BIG-AL View Post
    Yea. That's what I meant.
    2003-11
    450
    Sorry for the delay...
    When I run BIG AL's code I get an error
    ; error: ActiveX Server returned the error: unknown name: Point
    It is running into an error on this line
    and I am having trouble understanding what that line does.
    I don't want to modify the PointLabelStyle, I want to modify the PointStyle.
    2003-07
    561
    Mixing pointstyle and labelstyle does not help, think I got it right now.
    ; change a pt style not labelstyle
    ; by Alanh April 2021
    ; Thanks to Alan j Thompson for listselect.lsp
    ; for any one the style name is not the simple description eg PSM = #<VLA-OBJECT IAeccPointStyle 000001f89e718b20>
    (vl-load-com)
    (if (not AH:vercheck) (load "vercheck"))
    (AH:vercheck)
    (setq lst '())
    (vlax-for i (vlax-get *AeccDoc* 'Pointstyles)
      (setq lst (cons (cons (vla-get-name i) i) lst))
    (if (not AT:ListSelect)(load "listselect"))
    (setq ptsty (car (AT:ListSelect
                                        "Set new Point style"
                                        "Select style"
                                        10
                                        10
                                        "false"
                                        (mapcar (function car) lst)
    (foreach code lst
    (if  (= (car code) ptsty)
    (setq pstyle (cdr code))
    		(vlax-put-property obj  'Style pstyle)
    2002-01
    jUSt Here (a lot)
    9,106
    So I was right the entire time?
    2003-11
    450
    Thanks Big Al. That Worked!
    I always thought that lisp routines had to start with "c:", I guess it can be anything like AT: or AH:.
  1. 2017: How to add a cogo point along a 3D polyline at a random point
    By tadthurston725387 in forum AutoCAD Civil 3D - General
    Last Post: 2018-01-11, 01:42 PM
  2. 2016: Set All Cogo Points in Drawing to One Point Style
    By barshnizza494659 in forum AutoCAD Civil 3D - General
    Last Post: 2016-04-12, 12:56 PM
  3. 2016: Civil 3D > Map Annotation Label from Cogo Point number field
    By Trevor Deleske in forum AutoCAD Civil 3D - General
    Last Post: 2016-02-05, 11:31 PM
  4. Civil 3D 2010 cogo points & blocks
    By tommcgtx in forum AutoLISP
    Last Post: 2010-05-06, 01:19 PM
Tags for this Thread
