Page 3 of 3 FirstFirst 123
Results 21 to 28 of 28
Thread: writing a LISP to automate daily practice
  1. #21
    Certifiable AUGI Addict
    2001-03
    Tallahassee, FL USA
    3,667
    Default Re: writing a LISP to automate daily practice
    Quote Originally Posted by majou789377 View Post
    can you please explain more about the part of redefining the block?, it didn't seem to work for me
    Easy way is to simply start with a template with the block already defined how you want it.
    Inserting the surveyor's drawing will display the blocks as they were set up in the template not how they were defined in the surveyor's drawing. No redefining necessary.
  2. #22
    2020-04
    11
    I concur with Tom on the Student Version drawings. However, you can still automate a lot of these steps.
    I would first create the template drawing containing this CROSS block used by your surveyor. In that template, modify the CROSS block to fit your desired output. I would add three ATTRIBUTE DEFINITIONS to the block with each mimicking the text provided by the surveyor in your desired height and the layer the text is currently on. For the HEIGHT attribute, I would add a block placeholder for the Z coordinate with the appropriate precision. For the CO_ORD attribute, I would do the same for the X and Y coordinates with similar precision. Once you have that you can continue to the automation.
    Using your template, INSERT and EXPLODE your surveyor's drawing. This will make your CROSS block take precedence over the surveyor's block. All of the surveyor's CROSS blocks will be rewritten to match your CROSS block definition. You would then use the ATTSYNC command to update the location labels for the block.
    managed to do this. the rest didn't work. I copied the LISP you wrote and have the following message :
    Command: EASYBUTTON
    ; error: no function definition: PUTBLKATTRIB
  3. #23
    2020-04
    11
    the way I see is it can be done directly. I can just edit the current cross block that I get from surveyor by adding attribute of Z value as Opie explained.
  4. #24
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,106
    2
    How often do you want to make THAT edit of the block? You started this thread complaining about all the steps you currently have to do manually.
    What we are suggesting is you create a new drawing with the modified block to your desired appearance. You can even use the initial drawing from the surveyor and delete all object placed in the drawing. Once this drawing is saved as a template, create a new drawing based off of this template. Then, when you get a new drawing from the surveyor, insert the surveyor's drawing into the new drawing you created from the template.
  5. #25
    2002-01
    jUSt Here (a lot)
    9,106
    Command: EASYBUTTON
    I posted a link to the post that contains that function definition. I did not include it in my code.
    Anyway, the code I posted was untested. Since then, I have tested my posted code. It doesn't completely work. Parts of it does, though. You can work through portions of it to see what does work and what doesn't. Maybe someone can help determine a solution to fix the code portions that do not work. Unfortunately, I am down on manpower at work and am unable to continue to help.
  6. #26
    2003-07
    561
    Like Tom using block "cross" find the text next to it and replace all with new block with attributes, its a common task, post a dwg, if the E N are the block insert point that helps as only need to look for 1 text top left.
  7. #27
    2002-01
    jUSt Here (a lot)
    9,106
    Quote Originally Posted by BIG-AL View Post
    The "cross" block is currently just a "+". However, the drawing displays the x & y coordinates in one text object, the z in another text object, and then an ID is displayed in another text object. Fortunately, the "cross" block is inserted with the correct coordinates. This helps with the redefinition of the block to include attributes displaying those coordinates. The only sticking point is getting the ID into an attribute. Part of my code will do that and was functioning. Later code was not as I was writing it without access for testing.
  8. #28
    2020-04
    11
    indeed that is the point. editing the current drawing and save it as template.
    - - - Updated - - -
    you had been a great help already thank you so much for your time and contribution.
  1. daily occurrence --> ADT2005 "re-install"
    By markjnstne in forum CAD Management - General
    Last Post: 2004-08-06, 04:03 PM
