Thread: Parameter Formula Help
    2020-12
    2
    Default Parameter Formula Help
    Hi,
    I would like the "Tapeze L Angle Length" value to be 0 when the "Show Top Angle" visibility parameter is turned off. Is there a formula to achieve this? I only want it to show as 0" for quantity scheduling.
    2015-08
    199
    Default Re: Parameter Formula Help
    Is the "L Angle Length (Top)" the same value as the "L Angle Length (Top(report)" parameter at the bottom of your list? if so then you can use this formula.
    if(Show Top L Angle, Trapzeze - L Angle Length (Top , 0)
    I would suggest removing the brackets "()" and dashes "-" from your parameter names as this can cause issues when using the names in formulas.
  1. 2015: Need help with Revit yes/no parameter formula
    By willemdebruijn355287 in forum Revit Architecture - Families
    Last Post: 2015-09-09, 03:41 PM
  2. 2015: Help, Inconsistent Units in Parameter Formula
    By svaldes88482617 in forum Revit - Platform
    Last Post: 2015-01-09, 05:46 PM
  3. 2013: How to use this Formula,"Formula That Returns Strings"?
    By mike99 in forum Revit Architecture - General
    Last Post: 2013-01-09, 06:28 AM
  4. Project or Shared Parameter with Formula?
    By Haden in forum Revit Architecture - General
    Last Post: 2006-07-18, 09:31 PM
  5. 7.0/E - Renaming a Parameter - Change the name in the formula - G
    By Steve_Stafford in forum Revit Architecture - Wish List
    Last Post: 2005-09-06, 11:35 PM
