Thread: Change Opening Phases
    Wish List Administration
    2011-08
    4,581
    Default Re: Change Opening Phases
    Summary: Change the phase of openings created in model
    Description: Right now an opening's phase shows as that of the host. Would like to be able to change the phase of the opening itself, so if you want an opening in an existing wall, you can set the opening's phase as new construction and not see the opening when the view setting is set to new construction, previous phase.
    Product and Feature: Revit Architecture - Other
    Submitted By: Jmhanby on 04/14/2021
    Super Moderator CAtDiva's Avatar
    2015-10
    Where pedals spin to move wheels
    441
    Yes, it would be nice to be able to change the phases of these native Revit objects (not just wall opening, but the others too).
    For wall openings, I actually prefer to use a Generic Model family as then you can adjust the phase settings independent of the wall. And they respect the wall's room bounding property whereas "Wall Opening" objects do not.
