Anyone have a welding annotation/leader?
did you ever find one? I'd love to get my hands on it if so.
Alas, no. I tried making some, but there is no good parametric way to do so that I have found...I am fudging it currently.
I assume you tried creating an annotation family that looks like you want using parameters for the values like length and thickness etc? The only reason this doesn't work elegantly is the lack of control over the leader line origin...otherwise it could work.
You assume exactly correct. There is no way to tie the family to the leader. If you make the leader a part of the family, there is no way to control it's position. There is also no good way to do all the variations of welds...fillet, slot, groove...this side, opposite side, notes, field weld symbol, weld all around symbol...too many variations...too many family types...just not efficient.Originally Posted by Steve_Stafford
Since i'm also a welder i found welding annotation on some site just two days back, i dont actually remember but may be it was kinda like welderstream or welding stream, you can check which is it. Good day
Yes found it, it was on welderstream you can google it your self.
