Thread: Circle Sortings
    2011-08
    Vadodara, India
    147
    Default Circle Sortings
    Hi!
    I have some circles in polygon, I have a routine for sorting X-direction from left to right. I need also sorting Right to Left direction.
    Attached my routine for left to right direction.
    (defun bns_esort (ss func / a lst e1 na n)
      (setq ss2 (ssadd))      ;setq
      (setq n 0)
      (repeat (sslength ss)
        (setq na (ssname ss n)
        e1 (entget na)
        )         ;setq
              ;(setq lst (append lst
              ;                  (list (list (eval '(func e1))
              ;                              e1
              ;                        );list
              ;                  );list
              ;          );append
              ;);setq
        (setq lst (cons (list (eval '(func e1)) e1)
            lst
            )       ;cons
        )         ;setq
        (setq n (+ n 1))      ;setq
      )         ;repeat
      (setq lst (acet-list-isort lst 0))  ;setq
      (setq n 0)
      (repeat (length lst)
        (setq a   (nth n lst)
        a   (cadr a)
        a   (cdr (assoc -1 a))
        ss2 (ssadd a ss2)
        )         ;setq
      )         ;repeat
      ss2
    Avinash
    2003-07
    560
    Default Re: Circle Sortings
    Look into the VL-sort command it can have a > or a < which is left-right right-left etc.
    Something like this
    (setq ptlist
    (vl-sort ptlist
    '(lambda (x y)
    (cond
    ((= (cadr x)(cadr y))
    (< (car x)(car y)))
    ((< (cadr x)(cadr y)))
    2011-08
    Vadodara, India
    147
    not working, I have a list like...
    ((41.0 -25.0 0.0) (41.0 -72.6802 0.0) (26.0 -135.311 0.0) (33.025 -384.687 0.0) (41.0 -637.0 0.0) (33.025 -914.667 0.0) (41.0 -1248.24 0.0) (41.0 -1308.24 0.0) (29.028 -1599.86 0.0) (41.0 -1870.24 0.0) (33.025 -2086.43 0.0) (26.0 -2409.17 0.0) (33.0 -2452.83 0.0) (45.0 -2493.15 0.0) (26.0 -2493.15 0.0) (25.0 -29.0 0.0) (25.0 -29.0 0.0))
    2010-06
    962
    Here you go.
    (setq lst '((41.0 -25.0 0.0) (41.0 -72.6802 0.0) (26.0 -135.311 0.0) (33.025 -384.687 0.0)
                (33.0 -2452.83 0.0) (45.0 -2493.15 0.0) (26.0 -2493.15 0.0) (25.0 -29.0 0.0) (25.0 -29.0 0.0)))
    (setq srt:lst (vl-sort lst '(lambda (a b) (> (car a) (car b)))))
  1. 2014: Creating circle within a circle hatch
    By Ghostly AF in forum AutoCAD Customization
    Last Post: 2013-06-13, 08:03 PM
  2. How to Constrain circle with another circle
    By ljupadhyay in forum Revit Architecture - Families
    Last Post: 2010-10-05, 03:12 PM
  3. Dimension from face of circle to face of circle?
    By ljlange in forum Revit Architecture - General
    Last Post: 2009-10-18, 04:45 PM
  4. Distance from circle to circle
    By Brian.164262 in forum AutoLISP
    Last Post: 2008-04-24, 05:31 PM
  5. Circle Polyline (ie Circle with Width)
    By johan d in forum AutoCAD General
    Last Post: 2006-02-03, 11:16 PM
