Hi,
I would like the "Tapeze L Angle Length" value to be 0 when the "Show Top Angle" visibility parameter is turned off. Is there a formula to achieve this? I only want it to show as 0" for quantity scheduling.
Hi,
Is the "L Angle Length (Top)" the same value as the "L Angle Length (Top(report)" parameter at the bottom of your list? if so then you can use this formula.
if(Show Top L Angle, Trapzeze - L Angle Length (Top , 0)
I would suggest removing the brackets "()" and dashes "-" from your parameter names as this can cause issues when using the names in formulas.
