Thread: All structures dissapeared from my profile
    The Silent Type
    2021-04
    Default All structures dissapeared from my profile
    This first happened on my sanitary sewer profile. I turned on all layers, didnt show up. They still existed per the plan view and structure data table, but didn't show up in the profile itself. I edited the network to add another structure and pipe on top of the existing line in plan view and added that part to the sanitary sewer profile, and they showed up fine. I started playing with the START and END INVERT ELEVATION of the new pipe and discovered that the problem was in the START INVERT ELEVATION field. If I set the START INVERT ELEVATION to the same elevation as my existing pipe, down to the 0.1, it would disappear. When I changed it up or down by 0.1 it would reappear. I ended up moving my invert elevations down by 0.1 to make it work but now the problem happened on my storm sewer profile, where ALL structures disappeared, and the same START INVERT ELEVATION problem exists. I do not want to alter the inverts of the already existing storm lines as I have tight tolerances to work from. Has ANYBODY ran into this issue before, and if so, how in the world did you fix this? I have been at this for 3 days straight now and it's infuriating The file is too large to upload here.
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,100
    Default Re: All structures dissapeared from my profile
    Have you tried an Audit or Recover of the drawing?
    Do the structures display in a different profile view?
    Cairo - no, not Illinois
    5,069
    Are you DREFfing the pipe network into your profile sheets?
  1. 2014: My toilet has dissapeared behind a hatch
    By wharvey_jones380653 in forum Revit Architecture - General
    Last Post: 2013-05-16, 06:28 AM
  2. Display pipes and structures as a single line in profile
    By civil3d.wishlist1941 in forum Civil 3D Wish List
    Last Post: 2013-02-21, 09:27 PM
  3. 2013: Tags Dissapeared - Root Cause?
    By Skellerman in forum Revit Architecture - General
    Last Post: 2012-10-02, 02:04 PM
  4. Sort order when adding pipes or structures to profile
    By ReidS157562 in forum AutoCAD Civil 3D - Profiles
    Last Post: 2008-11-08, 04:34 AM
  5. Structures dissappearing in profile..??
    By whf in forum AutoCAD Civil 3D - Pipes
    Last Post: 2007-06-06, 05:51 PM
