Thread: AutoCAD to Alphacam - Object Order
    AUGI Addict madcadder's Avatar
    Too far from the beach
    1,054
    Default AutoCAD to Alphacam - Object Order
    One thing I have noticed with programming Alphacam from an AuotCAD drawing is...
    When I cross several geometries to all get cut with the same tool it orders the cuts by "first to last" as the objects were drawn in AutoCAD.
    I can change the order of operations in Alphacam, but by doing so I can change a 2 page report into and 8-10-12 page report, which isn't acceptable.
    Is there a way to change the order of objects in the AutoCAD database, so that I can fake the DWG into thinking one line was drawn before another in the file???
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,100
    Default Re: AutoCAD to Alphacam - Object Order
    I think using WBLOCK to create a new file is probably the simplest option. I believe the order of selecting objects will carry over to the new drawing, but I could be wrong.
    1,054
    That's a good idea. I will have to try that on a simple design to see if it works.
  1. draw order, display order
    By Wish List System in forum ACA Wish List
    Last Post: 2015-06-24, 12:57 PM
  2. Replies: 4
    Last Post: 2015-01-29, 04:46 PM
  3. 2012: Display Order / Draw Order
    By Iceberg in forum AutoCAD General
    Last Post: 2013-08-08, 02:33 PM
  4. Replies: 4
    Last Post: 2010-05-14, 08:38 PM
  5. LISP load order in relationship to CUI load order
    By Steve_Bennett in forum AutoCAD CUI Menus
    Last Post: 2007-01-19, 06:43 PM
