Thread: Custom Plot Size not appearing for Epson SC-T3000
    2005-01
    63
    Default Custom Plot Size not appearing for Epson SC-T3000
    I am setting two new workstations with AutoCAD LT using an Epson T3000 for plotting. Selecting Plot and then Properties, I go to Custom Properties which calls up the settings for the T3000, then under Size Settings add the Custom Paper Sizes. Clicking OK and OK saves the new PC3 file. When I go back to Properties again the new Size does not appear, however going back into Custom Properties and the T3000 settings it does appear. Have tried a couple of the suggested fixes found on the Forum but no changes. FYI, using the same steps I was able to create some custom sizes on another workstation a few weeks ago.
    Thanks!
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,100
    Default Re: Custom Plot Size not appearing for Epson SC-T3000
    Are the PC3 files located in the folder assigned in your configuration for Printer Configuration Search Path? And the associated PMP files would reside in the Printer Description File Search Path.
  1. 2013: Volume in Schedules appearing and not appearing
    By Chris.Partin in forum Revit Structure - General
    Last Post: 2013-02-20, 04:19 PM
  2. Printing to Epson
    By johnf.77896 in forum Revit - Plotting/Printing/Exporting
    Last Post: 2010-08-04, 08:03 PM
  3. Plotting problems with Epson EPL-N2750 printer
    By raymonds in forum AutoCAD Plotting
    Last Post: 2004-11-15, 01:43 PM
  4. Epson 7600 AutoCut to Exact Page Size
    By cjd.bradwell in forum AutoCAD Plotting
    Last Post: 2004-10-08, 04:36 PM
  5. Printer For Revit (Hewlett vs. Epson)
    By jamesmahoney1913 in forum Revit - Hardware & Operating Systems
    Last Post: 2004-05-11, 09:01 PM
