Thread: Make Island Detection default "Normal" instead of "Outer" in Hatch dialogue box
    Raleigh, NC
    751
    Default Make Island Detection default "Normal" instead of "Outer" in Hatch dialogue box
    I use the classic Hatch pattern dialogue box and remember years ago be shown once how to change a variable setting that would make the Island Detection default be normal instead of outer.
    How can I change it to default to Normal?
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    8,665
    Default Re: Make Island Detection default "Normal" instead of "Outer" in Hatch dialogue box
    In that dialog, you can set the radio button to the Normal style. Or you can use the HPISLANDDETECTION system variable and set it to 0.
    in the upper right corner
    3,325
    Thanks for this Opie!
    On a related topic, when I upgraded to Acad 2018 a while back, my hatch dialog box wouldn't show up when using the hatch or bhatch commands, I needed to type "S" (for settings) on the command line to get it.
    I've been too lazy to go looking to find out why, but this thread prompted me to go looking at all the HP settings to see if I could turn it on.
    Seems the initial value is "2" which turns off the dialog with "ribbonstate" on (which defaults to "1" [on] when loaded.. apparently) I don't really use ribbons either, so I could just turn that off too.
    Anywho, this helped me fix a similar problem so thanks!
    Ted
    Windows 10
  1. Creating fill hatch with an island
    By james120479 in forum Impression - General
    Last Post: 2019-08-22, 04:22 PM
  2. 2013: BPOly without Island Detection by default
    By Darren Allen in forum AutoCAD General
    Last Post: 2014-10-30, 05:39 PM
  3. Replies: 3
    Last Post: 2014-10-22, 06:06 PM
  4. 2011: How can I change the space between a hatch and an island?
    By Julesagain in forum AutoCAD General
    Last Post: 2011-02-10, 02:02 PM
  5. Command Line instead of Dialogue Box
    By archdraught in forum CAD Management - General
    Last Post: 2008-09-26, 07:09 AM
