hello everybody.
I hope you all can help me solve this little problem I m facing to and have no idea how to deal with: I have in the same dwg file around 90 solid blocks to be exploded for running the mass prop command. I would like to have a lisp to: 1. explode all the blocks 2 run the mass prop command (I need only I, J, K data) for every solid in the file, 3 report data for every component I, J, K and the block name it self.
When i explode the blocks i lose the block names and this is such a problem for me since I have to run this operation 90 times...
Thank you all in advance
Regards.
Francesco
