Thread: Publishing hanging up
    2003-12
    45
    Default Publishing hanging up
    I have a user in the office that is experiencing issued with the publish command. We loaded 2021 and he was able to publish once. Since that point the process hangs up and requires a the task manager to end the autocad session. Drivers have been updated and a valid pc3 has been checked. Looking for other avenues to explore to rectify this.
    Certifiable AUGI Addict
    2001-03
    Tallahassee, FL USA
    3,667
    Default Re: Publishing hanging up
    I tried to publish a drawing with three layouts a month ago that I'd published before three times and it errored each time having an issue with the Page Setup. I then plotted the three layouts with that same Page Setup assigned no problem. Never seen that happen before. Two days later I published the same drawing again and it worked perfectly.
    Sometimes there just isn't an answer.
    Three most useful AutoCAD fixes are restart AutoCAD, restart your PC, and try it again later this week!
    https://www.cadtutor.net/forum/topic...comment-580018
  1. PDF printing hanging
    By Chad Smith in forum Revit Architecture - General
    Last Post: 2005-05-04, 03:54 AM
  2. ADT Running slowly and hanging
    By Chuckyd67 in forum ACA General
    Last Post: 2005-03-18, 08:10 PM
  3. Everyone hanging around waiting......
    By Les Therrien in forum Revit Architecture - General
    Last Post: 2005-03-16, 02:03 PM
  4. Door Hanging
    By mark.77423 in forum Revit Architecture - General
    Last Post: 2004-11-01, 11:21 AM
  5. Challenge of the week-hanging chain link
    By sbrown in forum Revit Architecture - General
    Last Post: 2004-06-08, 03:41 PM
