Thread: Civil3D object enabler versions for AutoCAD Map 3D
    2005-06
    10
    Default Civil3D object enabler versions for AutoCAD Map 3D
    Hello,
    We're using AutoCAD Map 3D 2018 and 2019. We often receive .dwg files that were created in Civil3D (various versions), and we'd like to install object enablers for M3D to be able to handle the C3D-specific objects.
    It is not clear to me whether the version of the object enabler (e.g. 'Autodesk Civil 3D 2021 Object Enabler') refers to the version of C3D data that can be handled with (any?) AutoCAD Map 3D, or if it refers to the version of M3D that we have to have to use the OE?
    In other words:
    If we install 'Autodesk Civil 3D 2021 Object Enabler' in both our M3D versions, can we handle C3D objects that were created with C3D 2021 and earlier?
    Or do we have to use 'Autodesk Civil 3D 2018 Object Enabler' and 'Autodesk Civil 3D 2019 Object Enabler' (and in this case, does it matter what C3D version the data was created with)?
    Thank you for any clarification!
    r.
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,106
    Default Re: Civil3D object enabler versions for AutoCAD Map 3D
    If I remember correctly, you install based on the version of your software. If you are on 2021, then you would need the 2021 version of the enabler. I could be wrong, though.
  1. AutoCAD Web & Mobile App object enabler
    Last Post: 2021-01-14, 09:29 PM
  2. 2014: Etransmit Crashes AutoCAD 2014 when Civil3D object Enabler is present
    By jpcadconsulting347236 in forum AutoCAD General
    Last Post: 2013-11-25, 07:36 PM
  3. Replies: 2
    Last Post: 2009-12-14, 04:55 PM
  4. Installing AutoCAD Architecture 2009 Object Enabler (32 bit)
    By chrisgaldi in forum AutoCAD LT - General
    Last Post: 2009-03-12, 08:56 PM
  5. Civil3D Points from Map Object Data?
    By DWS44 in forum AutoCAD Civil 3D - General
    Last Post: 2008-09-19, 12:05 PM
Tags for this Thread
