select lines/curve tab, then create curves, I cannot get any of these functions to work.
it just gives me data in the command line about the curve I tried to create.
anybody else having this issue?
Hi
really need more information to help you here one of the typical mistakes that I hear is someone tries to use curve from end object and tries to create a curve from a Pline it won't work. can only create a curve from a line or another curve
after, or during the command hit F2 and capture what is displayed on the command line so we might see
what issue Civil3d or autocad is having with your selected lines or arcs
I tried using it again today in a different drawing. It seems to be working now. One thing that is different
is I have dynamic input on. I now get a popup menu to make selections. Previously I had dynamic input off
and I didn't get the popup menus. I'll continue trying it and if anything comes up I repost it.
thanks for the help.
The DYNPROMPTS had nothing to do with it not working, I just tested it with it on and off, no change.
So whatever was the cause in that other file, that most likely wasn't it.
Either way good to hear that it is working as expected for you.
