Thread: Export to atutocad from C3D not working in windows 10
    2021-06
    Post Export to atutocad from C3D not working in windows 10
    Dear Members
    I am using windows 10 OS, where in the Export from Civil 3D to CAD doesn't work. I am not sure if it a C3D issue or windows OS issue. Before installing windows10 , it was working fine. The EXPORT command works but it takes forever without actually exporting anything. Same is true for EXPORTTOAUTOCAD command in the command bar. Your advice is highly appreciated
    Regards
    Bilal
    2015-12
    Arizona
    2,478
    Default Re: Export to atutocad from C3D not working in windows 10
    Try the native command function
    Command: -AECOBJEXPLODE
    Loading AEC Object Explode...
    Explode AEC objects to primitive graphics? [Yes/No] <Yes>:
    Does that also fail?
  1. conversion from c3d 2009 to c3d 2004
    By NELSON_ORTIZ in forum AutoCAD Civil 3D - General
    Last Post: 2008-11-11, 01:04 PM
  2. Using C3D 2009 styles in C3D 2008.
    By eckdahlrd in forum AutoCAD Civil 3D - General
    Last Post: 2008-10-30, 06:35 PM
  3. Opening C3D 2009 with C3D 2008
    By bsolano in forum AutoCAD Civil 3D - General
    Last Post: 2008-08-06, 05:06 PM
  4. saving 2008 c3d down to 2006 c3d
    By charles.brown.158831 in forum AutoCAD Civil 3D - General
    Last Post: 2008-03-26, 02:46 PM
  5. 2006 C3D VS 2008 C3D
    Last Post: 2008-02-06, 05:11 AM
Tags for this Thread
