Thread: Dynamic blocks stop working in AutoCAD2022
    I could stop if I wanted to cadd4la's Avatar
    2001-12
    Newport Beach, CA
    399
    Unhappy Dynamic blocks stop working in AutoCAD2022
    Hi everyone,
    I'm have a problem with dynamic blocks not working in AutoCAD2022 but work fine in AutoCAD2021.
    The dynamic block is somehow locked and will not change, rotate, stretch, etc.
    Has a variable setting somehow change in AutoCAD 2022 to cause this?
    Cadd4la
    Turlock, CA
    6,420
    Default Re: Dynamic blocks stop working in AutoCAD2022
    I just tried inserting an old block from our symbol library into a new 2022 dwg and I can use it's tools. Can you post a sample dwg? Have you tried other blocks? in a new dwg?
    C:> ED WORKING....
    LinkedIn
    2001-12
    Newport Beach, CA
    399
    Ed,
    Thank you for replying but it's not the block that is the problem, I've been using AutoCAD2022 for months now with no problems with any dynamic blocks and the same file with dynamic blocks in it works in AutoCAD2021.
    it's got to be a variable setting.
    Regards,
    Cadd4la
    Turlock, CA
    6,420
    It would still help if you post a sample dwg.
    C:> ED WORKING....
    LinkedIn
  1. Dynamic Blocks - Creating dynamic bolt blocks
    By jake1889 in forum Dynamic Blocks - Technical
    Last Post: 2014-08-08, 12:56 PM
  2. Dynamic Blocks stop working
    By dduggins in forum AutoCAD General
    Last Post: 2007-10-10, 02:19 AM
  3. Replies: 39
    Last Post: 2007-02-06, 07:08 PM
  4. Copy (ctr-c) & Paste (ctr-v) would stop working in AutoCAD
    By tcrowder.84161 in forum AutoCAD General
    Last Post: 2006-05-12, 04:15 AM
  5. Commands stop working
    By ccowgill in forum AutoCAD General
    Last Post: 2006-03-23, 01:09 PM
Tags for this Thread
