Results 1 to 6 of 6
Thread: iLogic change colour depending on the value of a parameter
    2015-11
    Tasmania Australia
    4
    Default iLogic change colour depending on the value of a parameter
    Hi, I am designing a large tank as a part that will have about 112 features that will change colour depending on the value of a parameter.
    Below is the code I have working at the moment
    The tank will be covered in colored dots that will represent the wall thickness measure for and existing site tank
    The finished model will look a bit like a heat map showing the thinner areas of the tank.
    When the (wall thickness) parameters change over time the colors of the features will change to reflect the level of corrosion.
    The parameter will be updated manually when the model is revised.
    There will be about 56 parameters and 112 model features, and I was looking for some help in the best way to manage the size of the code without it becoming to huge to manage
    Parameters would be something like
    A0 = 4.6mm
    A1 = 4.9mm
    etc etc
    If (A0 < 3.1) Then
    Feature.Color("A0") = ("Red")
    End If
    If (A0 > 3.1 And A0 <6) Then
    Feature.Color("A0") = ("Orange")
    End If
    If (A0 > 6) Then
    Feature.Color("A0") = ("Green")
    End If
    Any help would be greatly appreciated. I am a weak coder, but I got this to work. Would love to get it in a concise format for the full 56 parameters.
    Thanks in advance
    Turlock, CA
    6,419
    Default Re: iLogic change colour depending on the value of a parameter
    You could put the parameters in an array and then call a color setting function for each array member.
    Sub Main()
    	Dim features(2, 50)
    	features(0, 0) = "A0" : features(1, 0) = 4.5
    	features(0, 1) = "A1" : features(1, 1) = 4.6
    	features(0, 2) = "A2" : features(1, 2) = 4.9
    	Dim i As Integer = 0
    	For i = 0 To 50
    		SetFeatureColor(features(0, i), features(1, i))
    	Next i
    End Sub
    Function SetFeatureColor(featureID, thickness)
    	Select Case thickness
    	Case thickness < 3.1
    		Feature.Color(featureID) = ("Red")
    	Case thickness >= 3.1 And thickness < 6.0
    		Feature.Color(featureID) = ("Orange")
    	Case thickness >6
    		Feature.Color(featureID) = ("Green")
    	End Select
    End Function
    C:> ED WORKING....
    LinkedIn
    2015-11
    Tasmania Australia
    4
    Sub Main()
    	Dim features(2, 50)
    	For i = 0 To 50
    	Next i
    End Sub
    	Case thickness >6
    	End Select
    End Function
    Hi thanks for you input.
    I am struggling to understand an implement this, probably a bit advanced for me.
    I am not clear on the work flow to make my parameters talk to the features.
    My test part has 4 features
    The test part has 4 parameters
    When I edit the parameter I am hoping to make the feature with the same name change colour
    The parameter is edited in a form in the part file
    Every 6 months the tanks has measurements taken and the part will be revised to show the 'at risk' points on the tank.
    Any help is greatly appreciated
    Thanks Peter
    2015-11
    Tasmania Australia
    4
    I got it to work with this code, but it is just bulky and clunky
    If (A0 < 3.1) Then
    End If
    End If
    If (A0 > 5.9) Then
    End If
    If (A1 < 3.1) Then
    Feature.Color("A1") = ("Red")
    End If
    If (A1 > 3.1 And A1 <6) Then
    Feature.Color("A1") = ("Orange")
    End If
    If (A1 > 5.9) Then
    Feature.Color("A1") = ("Green")
    End If
    If (A2 < 3.1) Then
    Feature.Color("A2") = ("Red")
    End If
    If (A2 > 3.1 And A2 <6) Then
    Feature.Color("A2") = ("Orange")
    End If
    If (A2 > 5.9) Then
    Feature.Color("A2") = ("Green")
    End If
    Turlock, CA
    6,419
    Can you post your sample part file?
    Also, please use code tags around your code. When you reply, click on the Go Advanced button and it will give you a more advance editor. Select your code and click on the # button and it will wrap your code with code tags.
    This revised code should work. You hardcode the list of features to track using the array. The function gets the parameter value and sets the feature color.
    Sub Main()
    	'Build an array of strings representing desired features
    	'Resize the array as needed.
    	Dim features(2)
    	features(0) = "A0"
    	features(1) = "A1"
    	features(2) = "A2"
    	'Iterate the array
    	For i = 0 To 50
    		SetFeatureColor(features(i))
    	Next i
    End Sub
    Function SetFeatureColor(featureID)
    	Dim thickness As Double = Parameter.Param(featureID).Value
    	Case thickness >6
    	End Select
    End Function
    C:> ED WORKING....
    LinkedIn
    2015-11
    Tasmania Australia
    4
    Red face Re: iLogic change colour depending on the value of a parameter
    Hi here is a test part that works
    There is an embedded form to edit the parameters
    Your code will help a lot though as I need 56 of these parts and each of these have 13 parameters
    The final model will look visually very different, I just wanted to get a working test part so the functionality is correct and the code is concise.
    Thanks Peter
  1. Replies: 1
    Last Post: 2017-10-04, 07:48 PM
  2. 2017: Family parameter value to acquire host parameter value
    By ray_bongalon in forum Revit Architecture - General
    Last Post: 2017-06-13, 11:13 AM
  3. Change all Objects of one colour to another colour
    By tburke in forum AutoCAD General
    Last Post: 2016-03-04, 01:53 PM
  4. DB apperance depending on attribute value
    By Macieto in forum Dynamic Blocks - Technical
    Last Post: 2014-10-12, 09:44 PM
  5. Replies: 7
    Last Post: 2008-01-29, 06:11 PM
Tags for this Thread
