Results 1 to 7 of 7
Thread: How-to Dimension Isometric drawings
    2005-10
    Jacksonville, Florida
    Question How-to Dimension Isometric drawings
    I'm a cad student and cannot figure out how to dimension Isometric drawings properly. I do not know how to format measurements on the same planes as the drawing and am getting some incorrect measurements as well as having to correct the angle the leader lines are on. Does CAD allow measurement on Isometric planes and if so how do I format them or turn them on.
    Thanks,
    Mary
    13,656
    Question Re: How-to Dimension Isometric drawings
    Hi
    Does this help...
    ID: TS46712 - Applying an oblique dimension in an isometric view
    Have a good one, Mike
    2005-10
    Default Re: How-to Dimension Isometric drawings
    editing the dimension lines after the fact is pretty much what I have been doing. I was hoping for a setting or format the Cad would know that I am already in Isometric planes and dimension accordingly...
    I really appreciate your in put none the less..
    Thanks,
    Mary
    0,0,0 The Origin
    8,570
    Quote Originally Posted by mjpestalitz
    Thanks,
    Mary
    If you want to do it the old way, use the Styles and Dimstyles in the attached drawing.
    The method illustrated in Mike's link is easier though.
    John B
    "You can't convince a believer of anything; for their belief is not based on evidence, it's based on a deep-seated need to believe." - Carl Sagan
    2009-05
    I open drawing iso.dim.dwg, what is TROTATE
    I do not see any setting in auotcad for this
    2009-06
    8
    Hi Kenneth,
    The TROTATE is a sub command in the command DIM. So to set TROTATE first you type in command DIM and at DIM: prompt enter TROTATE then it will ask you the angle. I don't know wher it is in the Dialogue Diplays as I am an old CAD user I use commands.
    2011-10
    Norfolk England
    38
    Hi
    May be a bit late in the day to reply to this thread.
    Here is my take on Isometric dimensioning, used ever since I first used Autocad somewhere about 2005.
    We always used the romans text font for engineering drawings so the dimensions styles are based on that.
    Use the attached file to set up the dimension style properties, line colour, type, weight and base line distance, text offset from Dim line to suit yor preferences.
    A block is used for the arrows
    The sizes used are for an A3 Piping Isometric, so resize to suit.
    Hope this helps somebody .....
    Geoff
  1. Isometric Dimension.....
    By somared in forum AutoCAD General
    Last Post: 2014-01-13, 05:51 AM
  2. Best way to do isometric drawings?
    By RyanSS in forum AutoCAD General
    Last Post: 2007-08-05, 11:24 AM
  3. Dimensioning isometric drawings in AutoCAD 2007
    By r.burks in forum AutoCAD General
    Last Post: 2007-05-07, 07:57 PM
  4. Make Isometric Drawings from the Piping Module
    Last Post: 2006-08-15, 03:00 AM
  5. Isometric Dimension
    By Merlin in forum AutoCAD General
    Last Post: 2005-12-01, 12:14 AM
